Question about Dell 3100cn Laser Printer
Why does my toner fade on the right side of a copy
  • 48 Answers
It is possible that your printer just needs to be cleaned. The following url provides instructions on how to clean your printer.
http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html#1088799
Posted on Sep 15, 2010
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
One side of copy is smudged with too much toner, while the right side is faded and too light to read.
100% the problem contains in toner cartridge. If the toner is refilled, probably there is a problem with "doctor blade" of the cartridge. Try to clean it very carefully, because maybe there is a "crystalized toner " on the blade.
Pifonski
Nov 04, 2013 | Samsung ML 2525 BW laser Printer
Fading copies
Hi
If you have stock toner for very long time, I suggest you just shake it well to distribute evenly the toner powder.
If this solution doesn't help, roller drum inside the copier that might worn out and needs replacement.
I hope it helps you.
Jul 21, 2012 | Konica Minolta - Magicolor 1600 1600w...
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
PC 920 Faded sides
hi
try this open the copier and remove Toner Cartridges and shake side ways for 5 times and try to make copy,if faded gone its better to replace Toner Cartridges for better copy quality
Dec 12, 2008 | Canon PC-940 Black and White Copier
Dell 3100cn Laser Printer Logo
118 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
