Question about Proform Exercise & Fitness
My Proform 8.5 personal fitness trainer will no longer work. The display is fine, but when I attach the magnetic key, it gives its normal beep followed by a stuttering series of beeps that are a slightly lower tone. The treadmill won't respond to any of the controls, it beeps the stuttering tone at me each time I push one. I've tried unplugging and replugging, I've tried the reset switch, both with and without the key attached. The machine acts fine (i.e. no stuttering beeps) until I attach the key. I've tried cleaning both the key and the receptor area to no avail. I've never had this issue with the treadmill before.
2 Suggested Answers
  • 103 Answers
SOURCE: My Proform 8.5 personal fitness trainer will no longer work
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
Posted on Jan 11, 2010
Testimonial: "Tim, Thank you very much for your help. I already had the console apart so I just unplugged the ifit section and it works perfect. Randy"
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
sincerely. God bless you
Apr 18, 2012 | Proform 6.0 CE Rear Drive Elliptical...
When I turn on my proform 650 cross trainer the display shows 8s and flashes brightly one time and then goes blank
1) tRY TO exchange new batteries by news one.
2) Use your calibration software by easy diagnostic and fix it.
3) Tight the flexible cord from key piney vs display board.
4) Tight the connector from display board vs, Main Motor board,
5)aTTACHED THE diagram for sensor reed switch adjusted by 1/8"
6) Test the main motor controller board for 115 Vca,
+5vdc FOR OUTPUT GOING TO DISPLAY BOARD.
7) tEST THE transformer see the tips.
8) Test the power supply for +5Vdc see if there are some componnet like resistor, capacitor, diodes, etc Burns.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness12_26_2011_4_50_52_pm.gifSee the block diagram for easy diagnostic that I did for people like your. Sincerely. Happy New Year G-d bless you.
ernesto cuadra
managua, nicaragua,
Dec 20, 2011 | Proform 650 Crosstrainer Treadmill
I have the pro-form 980 cs and the screen displays a bright blue color but no words on the display. It was working fine, but a storm over the weekend knocked out our electrical power. It has not worked...
Dear Friend:
Thank you by your request.
I will try to help you inmediately:
nstructions Things You'll Need
  • Phillips screwdriver
  • Allen wrenches (included with the Proform 980 and Proform 980CS)
  1. Power
    • 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 98CS and a horizontal switch on the 980 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
    Reed Switch
    • 1 Unplug the treadmill and remove the safety key.
    • 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 980 Interactive trainer and four screws on the 980CS.
    • 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
    • 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
    • 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
    Optic Sensor
    • 1 Unplug the treadmill, take out the key and remove the hood cover.
    • 2 Locate the optic disc and optic sensors. The optic disc is the only circular disc set between two optic sensors.
    • 3 Spin the disc with your hand. It must spin without hitting either of the sensors. Loosen the adjustment bolts that hold the switches in place with the included Allen wrench and adjust them to ensure they do not interfere with the discs' ability to spin. Tighten the bolts and replace the hood
    Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 28, 2011 | Proform 980 CS Treadmill
BUYER BEWARE!! I purchased the Nordic Track C2500 in 2009 and after 2 years of moderate usage (105 lb women walking 3-4 times a week) the console stopped working. None of the buttons respond and it beeps...
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
o 2
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
o 4
o 5
Check too:Optical Sensor. If have it
Sep 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Just assembled a new Nordic Track 2155 - demo is turned off but when key is attached it comes up 'Welcome User 1' and no other buttons will work. Pressing start and a speed button does nothing. ...
Watch this video and Steps:
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check too: Optical Sensor: if have it.
May 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
My NordicTrack A2050 no longer displays anything - it's about 7 years old. I ran on it, powered off, then my husband went to use it and the console wouldn't go on. We hit the 'reset'...
Watch this video and Step:
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Chech: Optical Sensor if have it.
May 18, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Proform 8.5 personal fitness trainer will no longer work. when I attach the magnetic key, it gives its normal beep followed by a stuttering series of beeps that are a slightly lower tone. The treadmill...
Good Luck! Tim
Jan 10, 2010 | Icon Exercise & Fitness
I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Apr 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
76 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
