Question about Conair HCT495 Hair Trimmer
I have a Conair GMT 255 shaver and the battery will not hold a charge. Can a replacement battery be purchased and is it easy to replace batteries?
Buffalo12980
  • 625 Answers
SOURCE: Braun 4501 shaver
go to the braun site for replacement parts or do a search in your browser for discount braun parts.
Posted on Sep 07, 2007
SOURCE: My shaver won't hold a charge.
this fixed mine. i noticed in instruction manual i copied off web that the base will completely discharge the shaver and then recarge it. its the nature of this battery type to accept a smaller charge each time. ignore the base. use or run the razor until lcd says empty. recharge useing shaver cord not base for 4 hours ignore lcd. i did this 5 times and the 6th time it took a charge and ran for 47 minutes. if this doesnt fix all you have wasted is a little time. ps if you do neeed to replace battery in razor cause its worn out, you will have to replace also the circuit that the battery is mounted on. why i donna know. good luck.
Posted on Oct 08, 2008
Cytherian
  • 124 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
  • 10865 Answers
SOURCE: I need a new battery for the conair gmt183
Hello. Just take the unit into radio shack and they will sell you the battery and install it for free. Joe
ps please rate my answer as very helpful.
Posted on Mar 25, 2010
brector3
  • 1612 Answers
SOURCE: Shaver no longer holds a charge for longer than 1
You can repair yourself if you are able to solder the new battery pack into place. You will find the correct batteries at shaveroutlet.com. See link below (you will need two batteries)
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below for information
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Nov 04, 2010
Testimonial: "Thank you"
My shaver would not hold its charge then finaly just stoped running
Sounds like the battery is dead. A replacement battery for model 7775X can be purchased at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
Mar 26, 2013 | Norelco Cool Skin 7775X Electric Shaver
Conair GMT 200T: is battery replaceable??
The battery is rechargeable, however if it is broke you should have a two year warranty. Hope that helps you
Sep 17, 2011 | Health & Beauty
Will not hold a charge-can I purchase and replace the batteries easily without soldering
The battery in your shaver requires soldering. You will fin the correct battery at shaveroutlet.com. See link below. Scroll down the page for tutorial videos to help with installation
Aug 06, 2011 | Norelco 7800XLCC Electric Shaver
Looking for a battery for a conair gmt180 trimmer.
My local BatteriesPlus store assembled a custom equivalent battery with a slightly higher capacity. I didn't know they offered this free service, took the guy about 5 minutes. Because the OEM battery is soldered onto the board they didn't install it but I did it myself.
Sep 18, 2010 | Conair GMT 180 NCS Beard Trimmer
I need a new battery for the conair gmt183 model..it's really old and it doesn't hold it's charge..where can I get one?
Mar 23, 2010 | Conair GMT182CS
May device it doesnt charge and the battery gets really hot
The battery pack sounds to be bad and in need of replacing. You will find batteries for most all shavers at shaveroutlet.com. You ill need to match the deminsion of your batteries to ensure that you select the correct type.
Note: If you require further assistance, be sure to inclide your model number
Feb 03, 2010 | Conair Health & Beauty
I have had my Conair GMT 800 for about 8 months. The battery will not hold a charge, I can't believe the battery goes that fast.
The battery is a custom made item and is not sold anywhere. It was made for this specific trimmer for Conair. I have the same problem. Great trimmer when it worked, much better than most. I actually purchased a Wahl (Made in USA) trimmer and am very happy with it, although it does lack some features the Conair has (or had). What can I say? Conair is a good company, but I guess this one did not work out.
Rom
Jan 31, 2010 | Conair GMT 180 NCS Beard Trimmer
Does not hold charge, is not up to efficient speed
kindly check your battery if you over charge it, and replace it with a new one.
Nov 12, 2009 | Conair GMT182CS
How to install included shaving foil on Conair GMT 400.It is not mentioned in the instruction sheet. The existing trimmer head is screwed on.
email, me at askmannyssharpening@yahoo.com and I'll send u a picture on how to do this on Conair GMT 400, Please send me the info that u are asking
Nov 08, 2009 | Health & Beauty
Health & Beauty Logo
97 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
