Question about Linksys Wireless-N WRT150N Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
    Problem Solver:
  • 9 Answers
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Posted on Sep 15, 2010
I have lost my wep key
Hi. I would suggest resetting the router to factory settings and setting up your wireless network again. There is usually a reset button on the back. Once the remote is reset, run "ipconfig" in the command prompt of your computer to find out the router's IP address. It's usually 192.168.0.1. Type the IP address into the address bar of your web browser to access the router's network setup wizard.
Hope this helps.
Aug 20, 2011 | D-Link DSL-G624M (0790069285783) Wireless...
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
My router problem was not resolved and I can't reach you guys 4 assistance!
... and your problem is _________________________ ???
With an Ethernet cable, connect the "wired" port on your desktop/laptop to one of the "wired" ports on the router.
Access the router's built-in web-server, and "reset" the router to "factory-settings".
Then, run the "Wired Networking Setup Wizard".
Then, run the "Wireless Networking Setup Wizard",
to configure your wireless network, for up to 250 wireless devices (iPod Touch, laptops, et cetera).
Dec 28, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
The modem's been changed and cannot locate the CD to the driver to connect to the internet. The model is DSL-G604T/AU V.A3.
Hi! your dlink dsl-604T is adsl router modem, you can access the setup page of your modem router by connecting your computer directly to the port1 of the modem router and the cable from your isp should be connected to the WAN port. u need to pull up the browser and type in at the url:192.168.1.1 and it will ask the username and password, by default the username is admin and the password is 1234 or leave it blank, but i suggest before u do this steps. u need to reset your modem/router. there is a reset button on the back of the router and press it for 20secs and then unplug and replug it after 10secs. after that u can pull up the setup page of the router.. to check the default gateway of the router, right click the network icon on the lower right of the task bar and select status and it will show the ip address, subnet and default gateway..
u need to know what internet settings u have with your internet provider, bcoz once u access the setup wizard it will ask u the type like auto-dhcp, pppoe, static etc.. if your isp gives u a username and pass to connect to internet u have to select pppoe or if u are given a static ip address setting u need to select static ip... just follow the setup wizard..
Aug 17, 2009 | D-Link DSL-G604T Wireless Router
Setup wizard doesn't locate wireless router.
Any old ethernet cable should be fine. The setup disc is generally used only for initial setup to establish communications between router and pc, and to also configure your internet providers settings. You can access your router from your pc by going to http://192.168.1.1 and you can change settings in the router from there instead of using setup disc. If you insist on using the setup wizard disc you usually have to set your computer's ip address to a specific number and possibly reset router to default state (see manual or http://www.linksys.com).
Jan 22, 2009 | Linksys Wireless-G WKUSB54GS Kit
D-Link DI 514 Wireless Router
1 Navigate to 192.168.0.1 in your web browser (FireFox, IE ect...)
2 user name: admin
3 password: (nothing) leave it blank
your in -
If not, push the reset switch next to the power cord-
repeat 123 - your in
Love WadeFU
Oct 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
Aug 30, 2008 | Linksys Wireless-G WRT54G Router
Since you're having problem in setting this router up, the best to way to set it up is by doing a mnual configuration and you dont need to use the setup CD that came with it, I'm suggesting you to call the linksys tech support and they will walk you through on the manual setup it will only take about 10 minutes this is the number 800-3267114.
Hope that helps.........
Aug 13, 2008 | Linksys Wireless-G Broadband Router
Can't bring up Setup Wizard
yeah the same problem. not able to launch the wizard from the URL.
Actually i was trying to change the password for the wireless secure access and i tried typing different combinations and got in problem, then thought of doing a reset and start again the whole configuration, so i did used the reset hole and followed the instructions as listed in the document (ie like doing the configuration for first time). after restarting computer and access the http://192.168.0.1 URL, nothing happens, i'm not able to get the setup wizard. I also noticed that the LEDs are displaying properly as mentioned in the manual... now.. how to get it setup wizard....
plz help
Apr 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Setup Wizard won't appear
Kate I first suggest reviewing this link and determining the model of the router.
http://www.dlink.com/products/support.asp?pid=316&sec=0#quickInstallGuides
Second did you buy the router new or used because a used router may not be at the default address 192.168.0.1 you expect. Assuming you can access the router with your computer and wireless card -- open a command window (Start > All Programs > Accessories > Command Prompt) and type ipconfig and press enter. If you cannot connect using the wireless use a wired connection to the router ports to get the gateway address as indicated above using ipconfig. There may be multiple connections however we are looking for one with an IP Address and a Default Gateway probably like 192.168.?.? where the first question mark is the same and the last are different. Use the default gateway address to access your router instead of the default 192.168.0.1. If the password has been changed meaning the router logon fails for you with the default password, the manufacturers documentation may describe a reset process to return the router to factory default including the password to allow you access (note the gateway address will also revert to the manufacturers default requiring a reboot or ipconfig /reset and ipconfig /renew to reconnect the computer to the router after the change.
Dec 02, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-N WRT150N Router Logo
305 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
