Question about Dishwashers
My dishwasher smells of burning and it tripped the electric
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. What happens over time is the motor pump assy starts a minor leak and the water drips from the stem seal straight down into the motor. The motor bearings eventually corrode and then the bearings lock up of corrosion in the motor armature cause the motor windings to lose thier shellac coating so the motor either overheats or shorts causing the electrical burning smell and the resulting circuit breaker trip.
There is of course the possibility of internal wiring chaffing, the heating element or water valve solenoid failure that could also cause a short.
The most common failure is the motor pump due to water intrusion. The initial leak is small so bu the time the home owner ever notices any leak the damage has already been done in the form of the motor pump assy.
Thanks for choosig FixYa.
Kelly
Posted on Sep 15, 2010
  • Dishwashers Master
  • 43,501 Answers
There are couple of things it could be...the most likely is that the motor has gone bad...they will smoke first and then trip the breaker...if you get under the dishwasher you will be able to follow your nose right to the motor is that is the problem...
The other possibility would be that the heating element went bad and melted something before it shorted and tripped the breaker...that to your should be able to see rather easily in the bottom of your dishwasher...
At either rate you should be able to smell the problem or see the burn marks...
heatman101
3 Suggested Answers
SOURCE: bosch dishwasher electrical smell
probably is, hit the breaker
Posted on Mar 31, 2009
  • 7 Answers
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Posted on Aug 11, 2009
Machine went bang mid cycle and tripped electrics. If power is sent to the machine it immediately goes bang and emits a burning smell. What is wrong with my machine?
One possibility is that water leaked into the wiring and shorted it. There may be an access panel in front that you can remove to look for signs of leakage.
Apr 25, 2016 | Candy 24 in. CD950 Free-standing...
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Our GE dishwasher has been working fine for years. Now it is tripping the braker? all wiring is good right to the dishwasher. We did smell burnt wires but it went away.?????
Your dishwasher may be damaged beyond repair. When I installed the dishwasher in my home I found that there is a surprising number of wires bundled under the dishwasher. If you are skilled in that field you can pull the dishwasher out and try to repair the damaged wiring under the machine. However once you've smelled burned wiring it means that there are potentially significant problems in there. You aren't smelling the burnt wires anymore because the damage is so great it's just tripping the breaker. If you continue to try and force the machine to work in this situation you may end up with a fire and further damage.
Please be careful.
Apr 06, 2011 | Microwave Ovens
Our dishwasher made a loud pop the other night, and there was a smell of burning plastic/rubber. Since then it has stopped working. No fuse was blown or tripped it seems to be local to the machine. I...
You would probably need a whole new motor but the nwith the smell of plastic you may also have a burn hole in the tub. Your best bet is to replace the whole thing. Sorry
Aug 03, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
I loaded my Bosch SHU3305 and started it up. It
Start at the main power connections underneath. Then look in the control board area next. Eric
Aug 09, 2009 | Bosch SHU3305 Dishwasher
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
"rubber burning" smell
check to see if the motor is overheating, the motor could
be getting hot causing the smell, if the motor is'nt overheating, then call the local repair man, we live in miami(florida), and we have a dish washer that keeps on rumbling, we are getting it fixed today, the only big big problem is it seems to draw alot of electricity when in operation, so there's my problem
p.s. is your dishwasher also rumbling and drawing electricity?
shawn henks
miami,fl
Nov 26, 2007 | Asko D1716 Built-in Dishwasher
Dishwashers Logo
1,089 people viewed this question
Top Dishwashers Experts
