Changed the play mode on Toshiba dvd player SD 3960 after it wouldn't play a disk and now I can't change it back.
  • 1 more comment
  • mimit63 Sep 16, 2010
    Changed it to something like YUZ...can't remember. Have tried to turn it off and and reset it. There is no reset button like many things. Oddly enough, it will play a regular dvd but no picture. This started when I had bought a dvd on the net that was homebaked and then the normal dvds would'nt play but the homebaked one would...so I started playing around with all the settings. NOw this one won't let me me change it back. Won't even bring up the screen to change it back- I know the remote works as it powers off and on.
    turned it off, meaning- unplugged for a time.
  • mimit63 Sep 17, 2010
    still doesn't work- won't allow me to get to the set up menu.
    President:
  • 2,777 Answers
Do you know what you changed it to? Have you tried unplugging the DVD player from the power source, letting it sit for 2 minutes, then replugging it? Does it play after that?
Thanks
Tim
Posted on Sep 16, 2010
  • Tim Grayson
    Tim Grayson Sep 16, 2010
    Ok, but you do realize there is a big difference between turning it off and unplugging it, from a settings standpoint, correct? Just want to make sure you tried both. Does your TV support HD? It possibly in a some widescreen / high res / progressive scan format that will not display on your TV. If that's the case you can attach it to another TV (possibly a friends, maybe at bestbuy, to "test" a TV with) and have it display there, then you can see what you are changing.
    Tim
  • Tim Grayson
    Tim Grayson Sep 17, 2010
    Still doesn't work meaning you tried attaching it to a HD tv?
    Hmm that is a very strange issue.... it sounds like it may be stuck in that mode. It may be related to the "homebaked" things you tried to run on it.. may have corrupted the actual software inside teh dvd player...
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 20, 2008 | Toshiba SD-3960 DVD Player
Can only play DVDs for one region code.
Most DVDs can only play DVDs from a single region. However, they sometimes allow you to change the region at least one time. Another option is to make your DVD player region free. This is a hack that can be performed. Once you do this, you can play DVDs from any region.
Please see the following link for more information:
http://www.videohelp.com/dvdhacks/toshiba-sdk760/6898
Jan 17, 2008 | Toshiba SD-K760 DVD Player
My Toshiba SD-3960 sound does not work.
First thing before a landfill is to go into the units menu and see if something in the audio got turned off if not then inspect the connectors on the back for breakage. Good Luck
Apr 02, 2006 | Toshiba SD-3960 DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
