Question about Audiovox D1500B Portable DVD Player with Screen
My red lgiht flashes when I;m trying to charge the battery. What does this mean?
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
My battery light flashes red then green then red and so on even though its plugged in. The power indicator says I'm fully charged. What doed the flashing red and geen mean?
Try removing the battery and just use the AC adapter. If the laptop functions normally then you have a problem with the battery charging circuit . Either your battery is defective or the circuit that charges it is defective ( meaning the system board).
Aug 02, 2011 | Dell Latitude D500 Notebook
What does flashing red light on wii dock charging station mean??
Make sure that when charging the battery pack it must be attached to a wii-mote otherwise this may cause a flashing red light. If the battery pack is attached to the wii-mote and you still have a flashing red light this may indicate that there could a problem with the battery pack itself.
Mar 30, 2011 | Nyko Charge Station for Nintendo Wii
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
Mar 19, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Audiovox D1500B Portable DVD Player with Screen Logo
50 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
