Question about LG WM-2277HW Front Load Washer
The machine doesnt complete its cycle it stops and say LE
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Got "LE" mark on LED
Hi
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | Washing Machines
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 29, 2011 | LG Washing Machines
Mitsubishi Washing Machine (English Manual) MAW-YP7 Manual Request
The spin cycle stops in less than a minute,it doesnt complete the spin cycle
Oct 30, 2010 | Washing Machines
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Jul 07, 2009 | Samsung WF337AA Front Load Washer
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machine Stopped Flashed ''LE''
First remove all clothes and look for anything like a wash cloth that may have become stuck, then remove the cord from the wall socket for at least 30 minutes to be safe, and try this again if doesnt work the first time, two, move the drum by hand, close the door, and see if fires up, if so run a 20 minute custom light duty cycle, third replace the drum positioning sensor, 6501KW2001A.
It can be bought on line for between 25 and 40 bucks
Will
Nov 12, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG WM-2277HW Front Load Washer Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
