Question about Mitsubishi Televison & Video
The bulb on my 72 inch mitsubishi 1080 HD burnt out. I replaced the bulb and the colour is coming in very distorted. Too much blue or red. What is my problem. I only had the TV for 3 years and did not watch that much TV on it. My email address bgob11@aol.com
  • 35 Answers
SOURCE: Mitsubishi HD 1080 series 41 inch flat schreen tv
is this a rear projection? if so.. the best advice is to have it professionally looked at. especially if it involves a cube. it can involve realignment or replacement of the cube
Posted on Dec 31, 2007
  • 208 Answers
SOURCE: Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Posted on Feb 04, 2008
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Posted on Feb 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Feb 15, 2009
skotkolr
  • 558 Answers
SOURCE: akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Posted on Apr 05, 2009
What universal remote control is compatible for the mitsubishi 1080 hd series i belive mine is 55 inches? i need to align the red n blue crosses so my picture is not blurry.
ANY mitsubishi remote will work, universal remotes will not do the job.
Is color skewed and or 3 d looking?
The more you tell me the better I can help you.
SD TECH
Sep 15, 2010 | Mitsubishi WS-65315 65" Rear Projection...
CAN NOT FIX CONVERANCE RED & BLUE ON MY MITSUBISH HD 1080 SERIAL ws-55311 NEED A MANUAL ALSO
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
Dec 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have HD 1080 and the images are sterched at the
You should be able to change the aspect ratios so your images arent distorted.
Jun 15, 2009 | Televison & Video
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a Mitsubishi DLP 52525 that has a bluish static
the DM and/or FMT boards are bad. the chassis needs to be rebuilt.
check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi 65" HD-1080 big screen tv. Today when I turned it on it had a red shadow all over it and the red tube was off by about an inch. The TV has an automatic convergence function that I...
Convergence ICs need to be replaced. post the model number and I will list which ICs you need and where you can get replacements with free installation instructions.
Apr 26, 2008 | Televison & Video
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Dec 31, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
