Question about Navman PiN 570 GPS Receiver
Info on fitting a new battery to Navman PiN570
To fit a new battery.
  • 32 Answers
Remove SD card and place the Navman on a soft surface face down so that you do not scratch the LCD screen. - Take out 4 screws ONLY. 2 under the gps antenna and two hidden black discs at either side of the bottom on back of unit,Make sure you use a small Philips screwdriver.
- Use your finger nail very carefully around the edges, go extremely slow to detach the cover. Once it opens, make sure of the Power switch button, they seem to fall off.
- Remove clear tapes at the battery connector. DO NOT pull up the connector, you need to pull sideways and make sure do not use excessive pressure while pulling.
- Place the new battery in same manner and also place battery cables neatly so that the do not come in the way while closing the cover. The LCD display should turn on. If it does not, look at the Battery connector and make sure it is all the way in.
- Put the cover back slowly and then make sure nothing is dangling along the edges. Do not forget to check the Power Switch button; it should be in proper place. Press the cover firmly, it should snap in place.
- Charge the battery fully before using Navman.
- Insert SD card. You may need to reload Navman application software or restore from SD card, if you stored on the SD card previously.
Posted on Jun 01, 2009
I bought navmn pin570 i opened the box try to install maps ask me for actvat key any help
Yes, for activate this maps, you must pay in navman web page this service. but, I am using TOMTOM, in PIN 570, and it's working fine!
Nov 08, 2009 | Navman PiN 570 GPS Receiver
Pockect pc is not connecting with disktop pc
Google activesync which is freely available as download on internet. If you run Vista, connect via Windows Mobile Device Center on your pc. The companion disc merely holds activesync and a 2002 version of outlook, which, if you have not got a more recent copy anyway, can also be downloaded.
Aug 31, 2009 | Navman PiN 570 GPS Receiver
Pin570 using garmin Mobile XT software,GPS not working
Try Start Settings System GPS and tap ON before starting the satnav program. Not all programs automatically switch on the GPS. On hitting ON yellow light top left starts flashing. Now start your satnav program..
Aug 08, 2009 | Navman PiN 570 GPS Receiver
How to change battery Navman icn 330
hi location inbrisbane to buy new battery for 330icn navman thanks
Jun 21, 2009 | Navman iCN 330 GPS Receiver
Battery type
IF IT HAS A BATTERY YOU CAN TAKE THE BATTERY OUT AND IN THE BACKOF THE BATTERY IS THE INFO.. ALSPO AS I KNOW IF YOU GO TO THE SITE OF YOUR LAPTOP AND LOOK UP YOUR LAPTOP U CAN SEE THE SPECS
Jun 06, 2009 | Computers & Internet
Navman SmartST software not compatible with Windows Vista
Run the Navman software in XP emulation mode. Do a word search in Google for "XP emulation mode in Vista" to get instructions on using emulation mode.
Mar 04, 2009 | Navman PiN 570 GPS Receiver
dear sir
i have a navman, icn 330. when i brought it i could set it from home, but it doesnt happen now. it only works when charging in the car and works only in the car now. What is the reason for this?
Aug 15, 2008 | Navman iCN 330 GPS Receiver
I have lost my navman pin570 companion disc. how can I get another
visit the micro$oft site and download the current version of Active Sync
http://www.microsoft.com/windowsmobile/activesync/default.mspx
you may also need the micro$oft outlook program, which is part of "ms office"
Apr 12, 2008 | Navman PiN 570 GPS Receiver
Navman Pin570 battery replacement
There are 2 little black tabs at the botton of the back that you have to remove, behind these there are 2 screws u remove, and flip the ariel up and there are 2 screws under there you remove also.
The body is clicked together use a guitar pick, ur fingernails or small scewdriver to seperate the 2 sections.
Inside you will see a few screws holding the systemboard down, if need unscrew them.
you will see the battery its stuck onto the system board... be carefull seperating it,.. use a flat intrument or a butter knife to work it of the board ( its stuck on with double-sided tape or some kind of silicon)..
unplug it,
plug your new battery in.. BONGO
Let me know how you go.
cheers
plato
Put it all back together again
Jan 22, 2008 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
147 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
