Question about Sony Playstation 3 (PS3) Console
Hard disk is damage how i fix it - Sony Playstation 3 (PS3) Console
  • 73 Answers
If u know what ur doing it's as easy and takeing it apart and installing a regurler computer harddrive.... but if u dont,.. it's best you send it in for repairs
Posted on Sep 15, 2010
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
My aspire 1810tz notebook unable to boot up. went into setup, unable to find hard disk.Help!
Try to check the connection of the hard disk inside maybe did not fixed properly. Just open at the back of your notebook where the hard disk was inserted. After that if did not works, just replace your hard disk it could be damage.
May 29, 2010 | Acer Tablets & eReaders
Laptop fell now have error saying hard drive damaged, how do i fix this please, regards Mags
Dropping a laptop has most likely damaged the hard drive, especially if the laptop was running at that time.
The hard disk needs to be replaced and Windows installed on the new hard disk, plus the laptop's device drivers and your programs.
If you cannot replace the hard drive and Install Windows yourself, then you need to ask a computer savy friend to help you or you need to take the laptop to your friendly computer shop for repairs.
May 14, 2010 | Computers & Internet
Hard disk
your seagate is absolutely damage. replace hard disk instead. maybe some repair shop can repair hard disk. Just try ok.
Dec 26, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
Nov 16, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard disk failure
Go to www.gillware.com They can get files off damaged hard drives. If they can't recover your data, you don't pay anything. When you fill the form out, check "I was referred by an affiliate." And enter code 10869.
Aug 08, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Sony Playstation 3 (PS3) Console Logo
18 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
