Pioneer SX1980 Stereo Receiver/Amplifier. It turns on but no sound is produced.
  • Anonymous May 18, 2008
    I have everything appearing to be coming on (leds),but no output to the speakers.I have hooked up to a different receiver and the speakers work.I took the cover off just to inspect anything that may be be wrong visually ,and nothing appears obvious.Hope you have a suggestion.Barry
  • blgmike Jul 24, 2008
    i have a sx 1980.
    powers on will run my reel to reel but the am fm will not work
Hello there;
This might be painfully obvious but to be on the safe side check to see if the jumper pins are in the 'Main Out / Pre-In' jacks. If there is no jumper pins you found your problem. Second option, after turning on unit in a QUIET environment with the volume at the lowest setting do you hear a click coming from the inside? If yes, this is good. If no, you have problems.
give the guys at Innovative audio a call. They are the best place for vintage audio on the planet.
www.iavscanada.com
Posted on Jun 19, 2008
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Only the center speaker hookup is producing any sound. When i hooked up my speakers to the front L and R as well as the rear L and R i get no sound, the only hookup that will produce any sound is the...
on the main board there is Amplifier its possible that its burned when you short or overload the speakers it could happend
let a technican check the Receiver
Aug 23, 2010 | Pioneer VSX-453 Receiver
Just fried my 2nd home stereo receiver
yeah check the ohms for the receiver an see what the subwoofer ohms are.that can fry them
Oct 04, 2009 | Pioneer VSX-D509S Receiver
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
Pioneer A/V Stereo Receiver - VSX-D466S
If they are around the audio amplifier IC maybe are damaged
Nov 04, 2008 | Pioneer VSX-D466S Receiver
Radio comes on but i cant hear any music
You may be connecting this stereo into an amplified system. If the original factory stereo worked with the factory amplifier, your stereo is not turning the amplifier on. If you purchased the aftermarket wire harness that mates to the factory stereo connector, hook up the "Amplifier Trigger" wire, this wire is usually blue.
Oct 16, 2008 | Pioneer DEH-P3500 CD Player
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
417 people viewed this question
 Grubhead
Grubhead
