Question about RCA F32650 32" TV
RCA TV F32650 32in
Need toknow how to set color back on my tv can you help
The colour is set through the hidden service menu. This web page has detailed explanations of how to access and use the service feature http://www.artofhacking.com/files/TVMODES.TXT
Posted on Aug 29, 2008
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
How do i get dish network to work on rca f25422 tv
Well, you have a couple options with this. You can use either coax cable, or RCA cables. If you use coax, you want to connect it on the receiver that says TV set out, and out the tv set on channel 3 or 4. If you use RCA cables, you want to connect these to the color coded connections on the back of the receiver labeled with a Green 1. The tv will need to be on channel 3 or 4, and a video in put, usually Video 1 or 2.
Becki Barned
DISH Network Customer Service
Feb 01, 2011 | RCA F25422 25" TV
How can I connect my vhs player to my insignia tv? It already has a built in DVD player? I've tried the tri color cords but they don't work.
I would need to know the model number of your TV to be sure. But the RCA plugs should work (tri-colored cords... Red, White, Yellow typically) But if it's a combo TV/DVD player... you probably need to change the input to AUX1 or whatever the tri-colored RCA jacks are plugged into... and not on DVD setting. Try that. and advise back!
Oct 12, 2010 | Insignia Televison & Video
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Philips dvp1013 how do I hook it up to direct tv box
Make sure that your tv has the required RCA connectors. They are normally Yellow(Video) Red and white (Adio left and right) Get yourself a set of RCA cables in those colors and plug the cables into the back of your dvd player. Make sure to plug the RCA cables into the INPUT connectors at the back of your tv. Change your tv setting to AV, and you should have picture and sound
Jul 31, 2009 | Televison & Video
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Kids play with remote i need to overide v-chip code for a rca 13" tv
Call the customer service number on the back of the set.
Oct 09, 2007 | Durabrand DU1301 TV
RCA F32650 32" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
