Question about Kenmore Refrigerators
Ice maker keeps dumping ice. think it's ether power board or control board. how do i know witch one to change as thier both exspensive. mod # 25344383401.
  • Anonymous Mar 19, 2014
    jumped controled board worked for two days andstop again
  • 2,272 Answers
The control panel board of your unit is faulty.
I will explain why:-- If the power board is faulty then the unit will not operate at all. But when the power board is ok and the control board is faulty the unit will have power and operate but will function the wrong way or some of the functions will not work properly.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 08, 2010
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Whirlpool mod.ed25pqxfw1 will not despense ice. motor will not run. is there a test procedure?
I found a parts manual through Whirlpool and it says your ice maker is mechanical type. Fill with tap water and let freeze and if ice maker cycles and dumps the ice but does not refill the the water control valve part number 2182106 but that number has now changed to 2188542. Try this test first and I will send the parts manual and user manual. The test will point to what is happening like water control valve or the fill thermostat inside the ice maker, Thanks, Sea Breeze
Mar 17, 2010 | Refrigerators
Ice maker does not work properly
First check to see if you still have the tech sheet, witch is located in the bottom grill or kick plate of the machine. This is located at the front bottom of the machine and should have 2 pices of papper in the kick plate after you remove it. Open both of the refrigerator doors and remove the kickplate. If they are still their, The direction for the ice maker and emiter board are their.
This Link should give you a download for the diagnostic sheet that will help you. start at page 5-1
Jan 11, 2010 | Refrigerators
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
The individual cubes turn into a huge block of ice
After the ice maker dump the ice it calls for water and pour water for no more than 7 seconds if is more and overflow the ice tray will leak on the ice bin and freezes all together , that means that the circuit board inside the ice maker is bad and need to be replaced but it will cost you almost as replace the ice maker and is easier ,two screws on the top of the ice maker and one in the bottom,a plug between the ice maker and the freezer wall ,and the plastic tube from what the water come into the ice maker.
Apr 07, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
GE refridgerator/freezer light dims when trying to use ice maker
check the ice bin to see if theres something binding the auger up. take it out and thaw it is so.
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
133 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
