Question about GE GSD53 Dishwasher
I have a GE black panel dishwasher. I am having trouble cleaning the panel. It looks like cleaner has dripped down it but no matter what I use it never looks any better. The panel sounds like hard plastic and is in perfectly good shape. It just looks bad. I've tried soap and water and other cleaners but nothing helps.
    Champion:
  • 246 Answers
There is a cheap way to replace the panel and that is on applianceart.com. They have replacement panels and covers, and even stainless steel.
Posted on Oct 29, 2010
Can I buy a new front for my ge dishwasher in stainless steelit is currently black
you should take a look at www.applianceart.com they have a variety of stainless, color and design solutions for replacing your dishwasher door panel
May 20, 2010 | GE 24 in. GHDA960K Built-in Dishwasher
My dishwasher is putting little black spots on my clean dishes, hard to get off
aluminum untensils have rubbed against the dishes,use a mild abbrassive cleaner to eliminate marks....... how do i let inlet water out of my candy dishwasher
Mar 30, 2010 | GE Dishwashers
Dishes won't come clean ... there are black and brown particles on them.
First off check the salt level in the machine then check there is cleaner in the compartment. Then go buy a small bottle of dishwasher cleaner (about 2-5 ponds) Follow all instructions and run the machine on hottest wash....Hope this helps
Nov 17, 2009 | GE Nautilus 24" Built-in Dishwasher
After cycle is complete my dishwasher doesn't fully drain water.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film(slimy looking substance).
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I just purchased a G.E. dishwasher with a black front panel that is glossy. My daughter used a mister clean sponge to clean it and is now full of scratches, is there anything I can use on it to get them...
Once paint is scratched it is scratched. There are cheap and inexpensive ways to cover that panel with a glossy black, or even stainless or white, or whatever. Go to www.applianceart.com, they have a ton of options to help your dishwasher getting back to its new look....and give your daughter a break, she was just trying to help :)
Mar 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Jun 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE PRofile Diswasher PDW9880
you probably need a new control panel. The panel isn't sealed to the face everywhere, and food or water runs down the internal cable.
my panel burnt up. replacing it fixed the problem.
I caulked it in with clear caulk to prevent a recurrence.
Apr 15, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
GE GSD53 Dishwasher Logo
41 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
