Question about Casio FX-115ES Scientific Calculator
I type in 273.15 25 and i want a decimal back, but it keeps giving me a fraction. how do i change it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To convert a single value between fractional and decimal forms, press SD. To have all results come out in decimal form, press SHIFT MODE 2 to select LineIO mode.
Posted on Sep 15, 2010
Hi, I have a Sharp ELW535 Calculator and by accident I changed the mode that it is in... so now it gives me a fraction answer and not decimal. Ex, I put in 52/48 it gives me 1 1/12 Do you know how to fix...
There is nothing to fix as what you describe is not a flaw, it is a feature. You calculator has a key marked CHANGE between (x,y) key and ) key. To change a result from fraction to decimal or from decimal to fraction, you press the CHANGE key.
Sep 05, 2011 | Sharp ELW535 Calculator
Why does my TI-30Xa calculator keep converting fractions to decimals? I type in a # then click the fraction key (1/x key) and before I can enter the denominator # it immediately says 0.33333333, how can I...
First of all, the "1/x" key isn't the fraction key, it's "1-over-x." Pressing 3 1/x divides 1 by 3, giving you 0.33333333 .
If you want to enter a fraction, use either "a b/c" or "d/c," located just to the left of the 1 key. You can convert between decimal and fraction with "F--D" just below that.
Aug 10, 2011 | Texas Instruments TI-30XA Calculator
When ever i type a dec on my casio fx 115es it keeps giving me a fraction and i dont need a fractions this problem has just started
To convert a single value from symbolic to decimal form, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Aug 01, 2011 | Casio FX-115ES Scientific Calculator
How do I convert decimal to fractions, and fractions to decimal with this unit?
Decimal to fraction: Type in your decimal (i.e. .5) Then press [MATH] > press [ENTER] on [>FRAC] Then press [ENTER] again Example: .5>Frac 1/2 For a fraction to decimal: Simply type in the fraction and press [ENTER] Example: 1/3 .33333333333 (*Note that the decimal value is truncated to fit the screen)
Hope that helps! Have fun calculating!
May 03, 2011 | Texas Instruments TI-84 Plus Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How do i convert 1.695652174 on TI-84 plus edition. i already try doing math key but it won't convert into fraction and keeps giving me same answer.
Answer is 39 over 23......or 1 and 16/23. Check your settings on the calculator. People are running into this problem with decimals and there is an easy fix.
Let's say you have a repeating decimal such as .16666.....If you type in .166 or .1666 or .16666 and check as fraction it will NOT work. Reason why is you haven't typed enough of the "repeating" numbers for the calculator to understand that it is in fact "repeating." If you have a single number ie. 1-9 you must type in a minimum of 11 of that number. Then it WILL work as fraction.
Let's say you have a 2-digit number such as 13. Then you need to type in at least 6 of that number. Say you want to convert 1.2181818 where 18 keeps "repeating." Well I only typed it in 3 times. It won't work to convert. But type in that repeating number 6 times and it will.
Again calculator need to know that it is in fact repeating. Only typing it in a couple times could still change the outcome so it will basically fail to show the fraction until it knows for sure.
Sep 14, 2010 | Casio FX-115ES Scientific Calculator
My calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
Sep 21, 2009 | Casio FX-115ES Scientific Calculator
Can the TI-30X iiS convert decimals to fractions and if so how?
type the decimal you want to convert then press math button scroll down to were it says frac which means fraction then press enter on frac then press enter again to solve and to change it to a decimal type the fraction and press dec instead
Aug 23, 2009 | Texas Instruments TI-30XA Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
