Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
Etdishwasher soap not disolving leaving a cloudy film on dishes
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Sep 30, 2010
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Glassware is cloudy
Nov 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not coming clean, film ring on glasses and dried grime on the utinsels. Have run through twice with vinegar, not sure what to try next. Checked basket/drain and it was not blocked just has a small...
That sounds more like a problem with your soap not disolving completly. Try these few simple things. First, run your hot tap at your sink until it gets hot, then start your dishwasher. What this will do is ensure that your "prewash" is using hot water.
The next thing, is you want to select the "heated wash" or "hi temp wash" option with a "normal wash" cycle. What the heated wash will do is ensure that during the main wash the water gets boosted to 140 degrees wich is the temperature that your soap breaks down at.
White film left on dishes is a classic indication that the soap has not disolved or broken down completly.
Oct 02, 2009 | Bosch Dishwashers
Dishes have cloudy film on them
Try this. I want you to run your dishwasher empty, on the hottest water setting. Let it fill and just before it starts the wash cycle put in three cups of white vinegar. I expect your jets are clogged and the vinegar should hopefully open the jets back up. You don't need to add soap during this cleaning process. Works just like when you clean your coffee maker.
Apr 23, 2009 | GE Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
