Question about JVC PC-XC12 Boombox
CD trays are locked close and will not open and unit will only power down by unplugging.
4 Suggested Answers
SOURCE: Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Posted on Apr 24, 2009
  • 11 Answers
SOURCE: DVD tray will not stay closed (empty or loaded) on
get a new dvd player
Posted on Oct 16, 2009
  • 208 Answers
SOURCE: when power is turned on
hi, could be the capacitors in the power supply on their way out especially if the problem has been getting worse recently
Posted on Sep 23, 2010
LOCK ON LG FA163
followt this step and fix it. God bless you
However there are a small hole in the CD/DVD burner use clip and make click and open it.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it. Service a DVD tray motor:
  1. Unplug the player and test the motor with multimeter
  2. Unplug the motor plug and spray it with electrical contact cleaner, then plug it back in.
To remove the motor, unscrew or depress the end of each bale and lift out the motor. Replace the motor if necessary.
Nov 23, 2013 | Computers & Internet
Locked dvd tray.
have you tried to unplug the unit from the mains power wait around a minute and power back on if not press the setup button on the remote and reset to factory defaults.
Thanks J
Feb 16, 2008 | Televison & Video
Pen gartridge jam
Is it an ink cartridge jam
Please follow steps below : STEP: Disconnect and Reconnect the Printer Power Supply
Unplug the power cord from the wall socket. Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Raise and Lower the Scanner Assembly on the Printer
Lift the lid of the scanner until the locking bar catches to move the ink cartridge carrier to the center position.
Release the locking bar and close the scanner assembly.
If the ink cartridge carrier fails to center, repeat steps 1 and 2
Scanner Assembly Open but Without the Cartridge Carrier Centering
STEP: Check to See if the Ink Carrier Latches Are Open
Open the printer.
Check inside the printer to see if the cartridge carrier latches that hold the ink cartridges down have popped open.
Close the carrier latches
STEP: Remove any Torn or Stuck Pieces of Paper from the Input Tray and Output Tray
Disconnect the power brick from the back of the printer.
Lift the scanner unit.
Look down inside the printer and remove any torn or stuck paper from the input or output tray by pulling firmly.
Close the scanner unit.
Reconnect the power brick to the back of the printer
STEP: Clear Obstructions From the Input Tray
STEP: Fan the Paper
Grasp the **** of paper at one end (Figure 1).
Place your thumb on top of the opposite end of the paper and fan the paper like a deck of cards.
Flex the paper back and forth, and then fan it.
Straighten the edges of the stack on a level surface.
Top of Form 1
Bottom of Form 1
Additional Information
It is quite possible for objects such as pens, pencils, paperclips, and other small items to fall into the paper input tray causing paper jams to occur. Follow the below steps to try and clear any obstructions that may have fallen into the printer.
Caution:
The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
Remove all paper from the input tray.
Unplug the power brick from the back of the printer.
Unplug the USB cable from the back of the printer.
Lift the printer up and turn it upside down.
Caution:
Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
Jul 19, 2010 | HP OfficeJet t65 All-In-One InkJet Printer
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Xbox
Keta
Have had this happen several times.. maybe due to my childish tempers and the xbox recieving the end brunt of the cheating games and my fist..LOL
Heres how I fixed this.
Your gonna have to open the unit up, very easy to do with several screws at the bottom.
The unit will break away and you will see a chrome protection piece which will need removed also, make sure the unit is unplugged.
After you have it broke apart manually open and close the tray, you will see the lock mechanism which the tray lowers into and the release .
Open and close this several times you may also want to blow out the unit and clean it while its open,{ I use a que tip and alcohol, allow to dry before doing anything}. Close the unit back up and restart it.
This should help.,
Dec 02, 2007 | Microsoft Xbox Console
Combo drive opens and closes automatically
Arav you will have to open this unit up, sounds as thought the units slider has passed the spring sensor. with the unit open manually open the tray, there should be a spring lock release on the right with it upside down facing you. slide the tray all the way back in until you hear it click and lock. You may want to do this several times to make sure no plastic pieces have broken off. If you see or find a piece come out then achances are the spring lock mechanism has snapped, not uncommon on this drive. The screws are easily located on the bottom.
Sep 12, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
JVC PC-XC12 Boombox Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
