Routers
Problem for Routers
Generic problem for all Routers
My NAT type is on moderate so I cant pla...
By braden666 on May 16, 2008
can you please help me
Clarification Request
Posted by miladi on Sep 16, 2009
NAT mode!?
Same Problem
Apr 12, 2009
-   i need to know how to set my motorola wr850g router to open-   ez_duzzit_40
Mar 20, 2009
-   I have checked my xbox 360 box and there is no disk, is there any way i can apply to get this disk. -   Guest
Jan 08, 2009
-   fo shiz my router is wack son moderate n stuff wats up wit dat????
-   sizzly
Dec 10, 2008
-   YO MY ROUTER IS ACTING DUMB ITS ALWAYS ON STRICT HOW CAN I CHANGE THIS -   Guest
Solution #1
posted on May 17, 2008
Somewhat Helpful)
shaggyrat
Rank: Wiz
Rating: 83%, 803 votes
your xbox should of had a disk with it to run your network settings and store them on a memmory card the properties as long as you have your network setup disk save the properties to memmory car of xbox and then you shouldnt have no more problems
but if you need to proceed further you need to set router settings manually
in internet explorer search bar type in this code here 192.168.0.1 this is your fixed router ip this will bring up the screen for router protocol
it will ask for name and password unless you changed the password and name it should still be normal
type=admin for name
type=password for password this will give info on your routers and specs
Was this helpful?
Yes
No
Solution #2
posted on May 04, 2009
Very Helpful)
richard_virg
Rank: Apprentice
Rating: 96%, 7 votes
I tried everything and eventually figured this out.  Do this!
Enable DHCP set the start ip to 192.168.1.100, and remove any static IP address on your xbox 360 (have it automatically detect connections)
Set the MTU to 1364.
enable UPnP.
if you are using wrt-dd (if you aren't, you should be)  setup QoS so xboxlive has premium priority.
And you have hit the ground running.  Even microshats own website wont' help you fix this stupid problem.
I promiss this will work ;)
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #3
posted on Sep 13, 2009
Somewhat Helpful)
okey2k
Rank: Apprentice
Rating: 75%, 2 votes
Thank your,richard_virg,your suggestion does work!
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
My 432BRP holds my laptop on the internet for about two minutes and then dumps it off losing the... (More)
Answer
my wireless router is locked and i don't know how to unlock it
Answer
Ihave a microsoft MN-700 router, Which I woulf likr to connect to my internet satelite and run my... (More)
Answer
I am being kicked off the network but all the other computers are not?
Describe your Routers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
