Question about Wharfedale Valdus 500 Speaker
Tweeters for Valdus 500
I love Wharfedale Valdus speakers, but I blew out the tweeters. How do I get parts? Thanks.
  • Anonymous Dec 31, 2008
    tengo un receptor denon de 75 rms yuno de los twiter de las valdus 500 ya no funciona y quisiera saber como solucionarlo o con que puedo suplirlo
  • Anonymous Apr 28, 2009
    I need 6 tweeters for the Valdus 500 speaker.
    Problem Solver:
  • 7 Answers
Tweeters for Valdus 500 see www.signalsuk.comTweeters for Valdus 500 - wecan.jpg
Posted on Jun 21, 2011
Hi, I am not sure if you have found the replacement; I have a pair of Valdus 500 tweeter not use.
Posted on Jul 28, 2008
  • djdivvy Apr 07, 2011
    hi i am intrested could u tell me where u r write back david
Not sure where you're located but I have a pair in Rhode Island for sale. They are immaculate with only about 10 hours use on them. Get back to me if this is of any interest. Dantemcm@aol.com
Posted on May 29, 2008
Connecting new woofers and tweeter, which color wire is positive and negative
Normally, the red wire will be right side sound and black/white will be left side. However, if you are hooking up power, red is positive and black will be negative.
Jun 17, 2014 | Wharfedale Valdus 400 Speaker
How do i connect Wharfedale 9.5 speakers to onkyo HT- R538 home theatre system
Take a look at the setup procedure. Your Onkyo may allow you to select speaker size and distribution of bass, etc
Dec 26, 2012 | Wharfedale Audio Players & Recorders
I have a pair of jamo R909 speakers that need crossover / board replacement--- any thoughts or suggested repair options? The company has been horrific. Love the speakers, but the company doesn't s
Hi Katrina,
Yes parts are available for your R909 speakers.
firstly I am surprised that you have managed to blow both tweeters and crossovers.....there must of been some serious distortion/amplifier clipping involved there???
So a couple of things.
Can you actually see damage to the crossover boards? If so what components have been damaged? i.e board loactions and parts.
The crossover is available but they are not cheap. $1560 each (AUS)
So it would be preferable and much cheaper to repair them at board level.
Tweeters are also available.. $745.00 each (AUS)
Regards John
jb@qualifi.com.au
May 15, 2012 | Audio Players & Recorders
Quite new speakers 9.1 but the sound is very dull - sounds like tweeters are not working can these be repaired
You didn't answer if they ever worked right.
One doesn't usually judge tweeter function visually. They don't actually move much.
Take a cylindrical tube (like from a paper towel) and place it over the tweeter to isolate it from the room sound and the woofer, then place your ear at the other end. Anything? Nothing?
What sort of signal are you feeding them? Let's look (or listen) to the source and how its audio gets to the speakers. Define the electronics, pathing and setup.
Maybe some history. Have you ever tried to blow them up in your enthusiasm for the new rig? If the tweeters are dead, that may have happened. Microphone use and feedback = dead tweeters.
Feb 20, 2010 | Wharfedale Diamond 7.1 Main / Stereo...
Necesito saber donde está el servicio
en la esquina a la par de la zapateriea
Jan 20, 2010 | Wharfedale Valdus 500 Speaker
I have 1 set of wharfedale speakers valdus 400 .power handling (programme) 150W .normal impedance 4-8ohms.1 of the tweeter is not working .please advise how to repair asap ,thanks
you should first try if the driver is really gone or not, maybe it's just a wiring problem, also there can be something wrong with the cross-over network. Check the tweeter with a multimeter, if you don't see something between 2-16 ohms, you need a new one (or two, you probably won't be able to find the original part, so you'll have to change both left and right channel drivers) but if you see the desired impedance on the meter, check the internal wiring, crossover solder joints, capacitors, etc. I hope this helps.
Jan 03, 2010 | Wharfedale Valdus 400 Speaker
Wharfedale
Hello georgesverme,
I'd recommend starting with the local importer of Wharfdale products to see if they have exact replacement tweeters for sale. Contact:
Bob Springston, Sound Import, LLC
Phone: (508) 422-9788
Email: sales@soundimport.com
If you are unable to get tweeters from them, see if they will recommend a replacement or at the very least, provide you with the specifications, including the impedance, crossover point,frequency response, and power handling capability. If they won't or can't provide the information, then you are on you own. You'll want a relatively high-quality product, most likely 8ohm (but could be 16), crossover between 5-8KHz, frequency response from crossover to infinity (or at least beyond the range of human hearing).
Then try www.partsexpress.com. They have a large selections of speaker building products and carry small tweeters like yours in several brands, price ranges, and quality levels. Vifa is excellent. Tang Band is good. Goldwood is acceptable for entry-level speakers.
Hope this helps.
Aug 06, 2009 | MTX Audio TX4001 Component Speaker System...
Wharfedale Valdus 400 Speakers
Yes, you can easily check it by removing it and swapping it with your other one. If the one from the second cabinet works, then the speaker itself has died. If not, either the wiring is the problem, or the crossover in the cabinet. If you take the first speaker that wasn't working, and put it in the second cabinet and it works, then likely it's your crossover. Please rate my answer, thanks.
May 28, 2009 | Wharfedale Valdus 400 Speaker
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Oct 13, 2007 | Audio Players & Recorders
Wharfedale Valdus 500 Speaker Logo
986 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
