Question about kawasaki Garden
Country Home walk behind mower won't start. No spark coming from the new spark plug.
  • 1,040 Answers
The coil is bad. This is the part that is connects to the spark plug.
Jim
Posted on Sep 16, 2010
Starter rope on walk behind mower is hard to pull so mower won't start
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck.
James
Sep 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
No spark-magnets ok on flywheel-new coil-good spark plug
unhook the wire that comes from coil to shut off switch and see if spark then
May 16, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
HELP, 2007 Toro walk behind mower
There is a drain plug on the block of the motor usually it looks square. if its not behind the blade on the under carriage, then it will be on top above the blades were the motor is visible. you may have to tip the mower on its side to completely drain all the oil. but the plug is always going to be on the motor either on the side or on the bottom. if the plug is on the bottom were the blade is remove the spark plug wire first. a mower can start if you turn the blade by hand and that would be vary bad news so always take the spark plug wire off and make sure it can not come in contact with the spark plug before going underneath the mower.
Jul 30, 2009 | Garden
Tecumseh Sears Eager-1 6HP mower will not start.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Jun 29, 2009 | Craftsman Garden
Garden Logo
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
