Question about Bosch 3107DVS Electric Sanders & Polishers
I replaced the rubber sanding pad but the screw keeps backing out during operation.
  • Bosch Master
  • 885 Answers
Some pads come with a new screw that has loc-tite on them. If you used the old screw when you put the new pad on, the loc-tite was probably dry and flaking off. Put a small drop of loc-tite on the threads, snug it down and let it sit over night and it won't come out anymore.
Posted on Sep 15, 2010
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Hook and loop pad
Try the amazon, here: Amazon com Makita hoop loop. Wish you best of luck. Cheers
Fred
Mar 25, 2009 | Makita BO5010 5" Random Orbit Sander
My sander is vibrating very badly. So much that it is difficult to hold. Can you tell me what the problem may be and how to fix it.
I'm going to take a stab at this, with the following caveat from the Porter Cable manual:
  • For your continued safety and electrical protection, brush inspection and
    replacement on this tool should ONLY be performed by an AUTHORIZED
    PORTER-CABLE SERVICE STATION or a PORTER-CABLE•DELTA FACTORY
    SERVICE CENTER.
    At approximately 100 hours of use, take or send your tool to your nearest
    authorized Porter-Cable Service Station to be thoroughly cleaned and inspected.
    Have worn parts replaced and lubricated with fresh lubricant. Have new brushes
    installed, and test the tool for performance.
    Any loss of power before the above maintenance check may indicate the need
    for immediate servicing of your tool. DO NOT CONTINUE TO OPERATE TOOL
    UNDER THIS CONDITION. If proper operating voltage is present, return your tool
    to the service station for immediate service.
Having read their advice, also take a look at the diagram of parts in this link http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=14279&typeId=11221&documentId=30477 and see whether you feel comfortable disassembling something like this. You probably won't have to tear into the motor housing, but if it look dicey to you,please go to the home page of that same link and find a service center near youto do the work.
With that in mind, consider the following. I have the same sander, and have used it as one of an arsenal of sanders for many years. I think I remember having an issue like you describe, about ten years ago. Now if I can only remember what I did to repair it.....just kidding.
It's possible the bearings are worn out and need to be replaced. In that case, you might be better off having it serviced by a professional shop who can also replace worn brushes and clean and lube it to factory specs.
But it's also possible that the screw that mounts the metal pad to the bearing (#114 in dwg.) has come loose. I think that was the case with mine, and it was not the same sander, it vibrated so badly. I remember having a definite reason to tear into it, and I needed it for a job.
You might be able to access this screw by lifting a flap of the rubber pad and removing a dust seal, but if you feel adventurous, remove the four screws that hold the felt or rubber pad on the base of the sander. Be careful, because if you're not very careful you may have to replace this pad. (It should be readily available for a few bucks somewhere local, depending on your location.) In my case I made a custom cork bottom pad that was a bit stiffer than the foam rubber to keep my sanding sheet flat, but that's another story.
If you get this far, check to see that the center screw hasn't vibrated loose. If it's in tight, you need to check for play in the bearing that the metal base (#127, bearing & pad holder) is mounted on. If that bearing goes, the works will vibrate. Replace it if you can detect any play at all between the center race and the bearings. I'd change it out just for good measure if you have used the tool a lot.
Put everything back together carefully, tightening all screws with the right driver. And hope for the best!
I hope this is the solution to your problem. If you need parts, consult the web site listed above. They should be able to sort you out. Good luck! Let me know how it works out, or if I can help in any other way.
Mar 19, 2009 | Porter Cable Tools & Hardware - Others
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
Switch sticks for the ice and water. It wont shut off
Remove the water drain and the two screws behind it and lift up to remove the push button panel,unplug the push button panel. remove three screws holding the dispenser unit in place,sliding the water uotlet out of the way as you do. Next get to back of rubber cover and put a little lubricant(silicone lubricant would work,not too much, then test.Then test and reassemble.
Burkes of Byron Ga and Orlando Fla.
Jan 29, 2009 | Maytag MZD2766GES Side by Side...
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Bosch 3107DVS Electric Sanders & Polishers Logo
153 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Tom Chichester
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
