Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
How far will a dishwasher pump waste - Hotpoint 24 in. FDW60 Free-standing Dishwasher
Can the dishwasher waste hose length be a problem for the dishwasher pump?
no that will be fine as long as your not trying to go up across will be fine
Apr 03, 2013 | Dishwashers
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
SMU2046UC: waste water won't empty. Wash cycle works like it should but waste water remains in the bottom of the dishwasher. Sounds like pump is humming and there don't seem to be any clogs in the system??
Most likely a blocked pump. You should be able to access the pump from the base of the unit under your filters. Remove the cover and rotate the pump impeller to free blockage then start any prog to check if pump is working,if OK reassemble, if not replace pump
Oct 23, 2010 | Bosch Dishwashers
Where is the filter to the pump?
The filter is in the drain at the bottom of the washing compartment. It only catches larger pieces of waste which could damage the pump impeller or block the waste outlet. Small to medium size pieces are pumped out to your food waste disposer (if it's connected to one) or directly to the drain.
Oct 14, 2010 | Maytag 24 in. MDBH950AW Built-in...
The dishwasher works fine if you let the waste go straight into the sink, as soon as the waste is connected properly it cuts out in mid program any ideas? Thanks Paul.
the pump what pumps the water away is seized or blocked or plain and simple goosed or the waste for the dishwasher is too high as per manufacturer
Jun 21, 2009 | Dishwashers
Mucky water in bottom of washer
Sounds like the machine is not pumping out the water at the end of the cycle.  There is a solenoid valve located near the pump down below.  It has a pipe which extends to the waste and another which goes to the wash arms.  The pump will either send water to the arms or the waste.  IF this valve is jammed...usually with food waste...it will not pump out.  Often, the valve can be cleaned and reinstalled.
Nov 13, 2008 | Admiral AW22 Top Load Washer
Error code f4 on my adp 5966 whirlpool dishwasher
Blocked waste outlet or maybe just a worn pump.
I fixed a new one today showing F4
I found a piece of broken glass stopping the waste pump.
Hope this helps
john
Aug 05, 2008 | Whirlpool Dishwashers
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
51 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
