Question about Dometic Rooftop RV Air Conditioner
I have a dometic roof top a/c for a travel trailer, model #59516.731G when the relay cuts on to cool it would make a loud buzzing sound but would function the way it should. freezing over sevral times. Untill yeasterday, the relat wont cut on to cool at all now. fan motor on both fan & a/c sides lo,med, hi still work. would this mean the thermostat has gone out? thanks for any and all assistance you can help with charles
  • tsi87supr60 Sep 15, 2010
    the freezing over part happend once or twice a month. i did jump 2 of the wire bypassing the thermostat turned on the unit and air was blowing relativly cooler. would this be the relay or the thermostat?
    Top Expert:
  • Dometic Master
  • 5,743 Answers
Yes if fan not on auto if wont turn on compressor
Posted on Oct 06, 2017
pierre1811
  • 144 Answers
SOURCE: coleman rooftop a/c coachman travel trailer
It's likely that the contacts are stuck closed. You can usually just tap them with a screw driver and they will open but then you should replace them. If you don't know where they are. Find the power wires coming inside the unit and follow them. Contacts are fairly easy to replace as long as you do it wire for wire. In other words when you remove a wire from the old attach it to the new before removing another. I hope this helps. Please don't forget to give me a Fixya rating.
Posted on Feb 26, 2009
  • 68 Answers
SOURCE: ATWOOD MOBILE FURNACE RUNS WHEN IT WANTS/
Check your furnace for power. will be 4 wires. power ground and 2 thermostat wires. Check for power at the time delay relay, if you have power there check for power going in the fan motor, if power in motor wire, motor is bad. If no power in motor wire and power going to circuit board take the 2 thermostat wire apart and wrap the 2 together comimg from the thermostat. Fan will stat in about 30 seconds. If it does you need a control kit in the ac. But sounds to me like you have a furnace problem.
Posted on Mar 19, 2009
motor1258
  • 6674 Answers
SOURCE: Turned AC thermostat to Cool today - AC didn't
Just clicking is all your getting from ceiling assembly? No other modes work such as fan, or furnace? If that's the case, check your circuit breakers to make sure it didn't trip.
Posted on Jul 28, 2009
  • 415 Answers
SOURCE: AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Posted on Mar 31, 2010
Testimonial: "You gave us a couple extra ideas than what we already thought of checking. Thank you. We will trade out parts from working one, see what it is. Thanks"
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
Dometic roof top rv ac not cooling
sounds like it is low on freon have someone check with gage and add more if nedded.
Jul 11, 2014 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
AIR CONDITIONER DRTIPS WATER INSIDE TRAVEL TRAILER
Get up on top the roof and remove the cover to the unit is what I would do. Clear the obstruction out of the drain pan and make sure the drain hose is clear.
Jun 11, 2012 | Dometic Rooftop RV Air Conditioner
Dometic fridge. cooling it while traveling
If the trailer have good shocks absorbers, is posible traver with the unit on 12volts conection.
Aug 11, 2009 | Refrigerators
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
THERMOSTAT TURNS FAN ON AND OFF, BUT COMPRESSOR WILL NOT COME ON. JUST BOUGHT TRAVEL TRAILER USED. OWNER SAOD HE THOUGHT A FUSE NEAR COMPRESSOR ON ROOF.
Now the owner He's smiling, I asssume it is an older unit make sure the t-stat is set properly.cooling likely compressor issues could be start components or bad compressor get qualified service Good luck Tom
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm a/c
We had this issue also and dirt daubers had built a nest on the end of the fan blade
Jul 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
80 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
