Question about Kenmore Refrigerators
Kenmore Refrigerator I replaced my ice maker with a new Ice maker from sears. It does not seen to be working. Is there a way to test the Ice maker and is it on some kind of timer so the water will drop in the ice maker to freeze. I want to try and cycle the ice maker to verify its working. It is the correct ice maker and it hooked up just like my old one. It had the same wiring harness as the old one and match up perfect.
    Genius:
  • 1,073 Answers
It has to cool down to 17 degrees f to start a cycle and will take another hour plus to make the first set of cubes
if it had already been this long
is there water in the ice maker
if so check the connection at the ice maker again
if good then take the ice maker back and get a new one
there is a problem in the ice maker
Posted on May 16, 2008
How can I get my Kenmore Refrigerator Model 501-7835# Ice maker to work. Stopped working.
Perhaps you can call your local Sear store and ask them what course of action you should follow.
Someone will need to take the refrigerator ice maker all apart and find the part that is broken or out of adjustment.
God bless your efforts.
Jan 08, 2016 | Kenmore Refrigerators
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hgkl
Jun 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG LRFD25850 French Door, Fix or Repair Daily
You are expereincing poor service. The techs that are working on your unit do not know what they are doing. There is no problem that can't be resolved on appliances. My suggestion to you is to find a really good LG tech in your area to repair this problem. There are only so many things that can cause these problems.
Jul 24, 2008 | LG LRFD25850 French Door Refrigerator
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
113 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
