Question about ViewSonic G71F+B-2 17 in.CRT Conventional Monitor
G71f+ monitor I just bought a SonicView G71f+ monitor and I can't get it adjusted correctly my msn screen is out of range and I can't see the clock. The left side of the screen is fine
  • 3,037 Answers
In your osd screen menu, there should be a reset button, click on this and your screen should fit perfectly.
Let me know if you have trouble finding this
good luck
Posted on May 16, 2008
  • Benjamin Patri
    Benjamin Patri May 16, 2008
    you might find the reset labeled as Recall, if it doesn't fit perfectly on the screen then first resize the picture horizontally, and then move it horizontally.
    Then resize vertically, and move vertically and it should be pretty simple to do.
    Please keep me updated on this problem
    President:
  • 1,944 Answers
Did you try auto adjusting the screen?
Grey Wavy Lines On My Monitor
First of all, try using a different monitor cable. If the problem is still present, make sure that your monitor's image is correctly adjusted. Most monitors provide an 'auto adjust' function. This page can help you find out whether your monitor's clock and phase are correctly adjusted:
http://www.lagom.nl/lcd-test/clock_phase.php
It also provides different test images that can help you with locating your problem.
Hope is helps, cheers.
Jun 21, 2013 | Computers & Internet
I am putting my old computer (Dell XP) in garage to use strictly to view files, play dvd's/cd's, etc. It is not going to be used to go online to internet. I hooked up...
Hi there.
You'll need to adjust the refresh rate. I have recently written a tip on adjusting a monitor's refresh rate. I suggest you give it a read and let me know how it goes.
You can see my tip here:
http://www.fixya.com/support/r9352855-adjust_or_change_monitors_refresh_rate
Enjoy my tip.
Slasher_X
Sep 24, 2011 | ViewSonic VX1935wm LCD Monitor
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
May 11, 2009 | ViewSonic Graphic VG2021m LCD Monitor
On startup the screen shows ( out of range )
It means your system display card settings are too high for your monitor. Boot your system into safe mode and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced and you should be able to adjust the vertical frequency down to 60hz or 72hz. If not, then go to the monitor tab and load a generic monitor driver.
One time, I bought a repackaged display card that had been set too high and I had to reload the card driver in safe mode to get it to work correctly.
pls rate my solution
thankyou for using fixya
Feb 19, 2009 | BenQ FP531 15" LCD Monitor
Viewsonic g71f+
the feature will be called Auto Adjust on your osd menu, I'm not quite sure where exactly it will be but by clicking on this within the menu will fit it perfectly to your screen. It possibly will even be it's own button on the screen. Since I am not totally familiar with this exact model, I can't be more specific but if you are having trouble, please let me know the options and I can tell you where to look since all monitors are basically the same.
May 17, 2008 | ViewSonic G71F+B-2 17 in.CRT Conventional...
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Sep 02, 2007 | Audio Players & Recorders
ViewSonic G71F+B-2 17 in.CRT Conventional Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
