Question about Kenmore Washing Machines
Regarding Kenmore Oasis mod. 110 27072600 Ser. #CT1570208, washer comes up with LF on the rinse cycle on normal wash cycle. When it gets to the rinse cycle, it flashes LF
  • 1 more comment
  • dharmon3561 Sep 15, 2010
    Also, not all of the different cycles does. The heavy duty doesn't, the express cycle doesn't. This always comes up on the rinse cycle.
    If we perform those tasks and it still doesn't work...what then.
    Danny Harmon
  • dharmon3561 Sep 16, 2010
    As soon as my husband comes home I will give him the information. I would like to keep this thread open until he tries everything out. Is that allowable.
    Top Expert:
  • Kenmore Master
  • 76,846 Answers
LF is a failed water inlet valve either hot or cold sets the code, try using just hot then just cold settings and see if the code goes away, if it does then the hot or cold water solenoid valve at the back of the washer is defective
Posted on Sep 16, 2010
  • yadayada
    yadayada Sep 16, 2010
    hello
  • yadayada
    I have given you the correct info for this code, please accept my answr.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won't change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 15, 2010
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis model 110.27032600 LF error. had an issue with the washer cycling through all the lights, would turn it self on etc. Had the repair man come out and he replaced the computer board....
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis He washer has a problem with getting stuck when it's in Normal wash at the 17th minute in Rinse where the cold water will not dispense. It goes around slowly for a long time until...
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
250 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
