Question about Kenmore Washing Machines
My kenmore washer will not spin model number 41744082400 everything else works should i change control board
  • 3 Answers
No that will not solve your problem. The ctrl board isn't reading movement from the motor. Replace the motor only. maytagplb@yahoo.com
Posted on Sep 19, 2010
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
My washer is one of the first front load washers and it no longer spins
It is probably the motor control speed board. Without the model number, it could be also not spinning due to pump clean-out full of debris and going into a long drain which will not let it spin. Also, if it is an older model and the cover on the wire connections on the speed board has come loose, one connector usually comes loose as the cover has a piece of it that extends down to hold it in.
Jan 29, 2010 | Kenmore HE2 Plus Front Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Error code LOC
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Kenmore front load washer problem
i would say you have a bad motor control board
Feb 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont spin
You may be right, but before you rule completely on the motor, have you checked the Spin Control (sometimes referred to as a Motor Control Unit)? My experience with this unit usually has the Spoin Control board going bad more frequently. There should be a tech sheet located inside the washer behind the front panel under the door somewhere. The tech sheet should include all steps necessary in determing how to rule whether the motor windings are good, or the whether Spin Control board has failed. If you decide to replace the parts yourself, you can find them at repairclinic.com and searspartsdirect.com. Repairclinic has better pricing, but Sears has better diagrams used in parts identification and troubleshooting. The parts you may need are as follows:
Repairclinic:
Item 1206430 Spin Control
Item 823073 Motor-sole
Searspartsdirect
Item 4 (p/n #134149220) Speed Control (Under "PANELS/HOSES" heading)
Item 19 (p/n # 131770600) Motor-sole (Under DRUM/MOTOR" heading)
Of course...you can do your own comparitive pricing if you don't wish to shop online. Just use the Sears part numbers as a reference.
I hope this helps. Post back and let me know if you need further assistance.
May 02, 2008 | Kenmore 43142 Front Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
153 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
