Question about Amana ALW480DA Top Load Washer
Amana washer walks across the floor during the spin cycle. The washer now sets on a slanted floor (1/2 inch every 12 inches. However the washer has been leveled using the feet adjustments. Can this be corrected or is it time to buy a new washer?
  • 1314 Answers
SOURCE: LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Posted on Jan 02, 2008
  • 489 Answers
SOURCE: Walking Washer
The best way to fix this problem is to adjust the front legs while the machine is spinning a full wash load.  Put in a load of clothes and run the machine to get the clothes nice and wet.  It will take about 5 minutes to get them completely wet.  Next, turn the washer off.  Now, turn the washer back on and push the spin button to select the extra fast speed.  You washer will go into a drain mode and then begin to toss the load into a balance spin mode.  Once the washer is spinning the clothes, check the balance of the unit by pushing the front left corner of the washer towards the right rear corner and right front corner towards the left rear corner.  If the sound of the washer quiets down on one side vs the other side, adjust the front leg to quiet that side.  Do not attempt to adjust the rear legs as they do not require adjustments at all.  Everything adjusts on the front legs.
This procedure works if the floor is sturdy enough.  If the floor is old and the wood is weak, it will not work.
Posted on Apr 27, 2008
  • 1462 Answers
SOURCE: Frigidaire Infinity front load washer This
have you removed the transit bolts and any packing. this is the most probable cause
Posted on Jul 06, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
vickygomar
  • 460 Answers
SOURCE: Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
Posted on May 08, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
During the final spin cycle, our front loading whirlpool is making a really loud noise - it sounds like a train is going through the house. It is in the basement on a concrete floor.
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer walking across the floor in spin cylce
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
Dec 20, 2007 | Maytag Legacy Series Top Load Washer
Amana ALW480DA Top Load Washer Logo
55 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
