Question about Car Audio & Video
Where do I get replacement lamps for the display on a Delphi 12220949 car stereo? It is in a 2002 toyota Matrix.
  • 1 more comment
  • jercoleb Sep 15, 2010
    On the face circuit board there are three little lamps that can be replaced by desoldering from the circuit board. These are the backlights for the display. I just need to know where I can purchase them. Thanks.
    There are three backlight lamps on the face circuit board. These supply backlighting for the display. They are soldered to the circuit baord. Where can I get replacement lamps?
    Thanks for the help.
    President:
  • 2,777 Answers
I don't believe there are replacement lamps for that unit, if the display has died or the backlight has died, it is part of the actual display. That model is a Toyota exclusive... you may be better off just getting a replacement unit from ebay of the same model if that is what you are looking for. There is no easy way that I know of to "re-light" the display without replacing the whole face, which is nearly impossible, aside from buying another unit and taking it off of that, and if you are doing that, you may as well use the other unit...
Tim
Posted on Sep 15, 2010
  • Tim Grayson
    Tim Grayson Sep 15, 2010
    Hmm, ok I think I am thinking of another model then, if you are going to be able to get those lamps it will be from Delphi directly, I can't find anyone that sells "delphi" parts... I'm sure they don't make the lamps of course, if you can get an OEM type number off one I can locate it for you. Otherwise you will want to call 877-Go-Delphi or 1.888.809.9800to try and locate the lamps, those are both numbers for Delphi.
    Sorry about the confusion :(
    Tim
  • Tim Grayson
    No worries my friend, sorry about the confusion the first time around.
Radio has no power
in the vehicle there are built with a individual fuse for them,like stereo and room lamp.please check the fuse under the dustboard locate the stereo fuse,if busted replace it,thnx
Aug 31, 2011 | 2002 Toyota Tacoma
How do you change the clock on a 2001 honda crv
The clock removal instructions are available at www.autoclockrepair.com
If you have a defective clock, we offer a very reasonable repair service with a lifetime guarantee.
Subaru Forester 1998 - 2002
Subaru Impreza/WRX 2002 - 2005
Toyota 4Runner 1996 - 2002
Nissan Pathfinder 1996 - 2004
Honda CRV 1996 - 2001
Toyota Tacoma 1995 - 2004
Toyota Rav4 1996 - 2000
Toyota Land Cruiser 1996 - 2002
Toyota Camry/Corolla 1996 - 2004
Lexus ES300, GS300 1997 - 2004
Saab 9-2x 2004 - 2006
Toyota Matrix 2003 - 2008
Toyota Sienna 1999 - 2003
Ponitac Vibe (Voltz) 2003 - 2008
Suzuki Aerio, Vitara mid 2000s
May 31, 2010 | 2001 Honda CR-V
Dashboard lamps out various areas how to change
you must take off cover around a/c, stereo and dashboard. take out all screws. its a pain a big pain. the whole tach and all gauges comes out and on the back theres about 40 bulbs that u can change out. take bulb with you its a help.
Mar 29, 2010 | 2002 Toyota Tacoma
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
Remove radio
Replace the CD player. To pull the plastic baffle off the dashboard: Adjust the heating vents so they point downwards. Grab the plastic bar between the heating vents and the stereo. Pull. Remove the screws from the front of the mounting brackets. Pull out the crappy stereo. Unplug the antenna and the wiring harnesses. Transfer the mounting brackets to your new stereo. Cut off the big wiring harness (unless you're lucky enough to have a replacement stereo that accepts the same kind). Connect the wires to the wires on your new stereo's harness. For more info: check the website: http://tomclegg.net/toyotastereo
Jul 15, 2009 | 2002 Toyota RAV4
2005 Matrix Clock fades in & out(mostly out)
This is a common problem with many mid 90-2000 vehicles. I offer an affordable solution with a lifetime guarantee. Check it out:
www.autoclockrepair.com We fix clocks form the following makes
Honda CRV 1997 - 2001
Jun 07, 2009 | 2005 Toyota Matrix
Clock
www.autoclockrepair.com. I have the matrix removal instructions there as well.
Toyota Camry2_bing.gif/Corolla 1996 - 2004
Mar 28, 2009 | 2006 Toyota Matrix
Digital clock not lit
Mar 10, 2009 | Toyota Vehicle Parts & Accessories
Playing video audio through car stereo Toyota Matrix
You're probably gonna need a wired FM modulator. That part will take an audio output and run it into your antenna plug on your radio. It will use a FM channel, but it's wired directly to your stereo. So no static as found with wireless FM transmitters.
Jan 20, 2009 | Audiovox AVD300T Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
