Question about Oster 76076-010 Hair Trimmer
Trying to rewire a oster 76 classic model. i replaced the on off switch and dont remember how to put it back together
SOURCE: I need help!!!
if you have a single speed (on off) clipper, it should only have 2 wires which go on either way. If you have a 2 speed (off low high) clipper there should be 3 wires, and they must go on exactly as they were. you won't blow anything up if you wire it wrong you just wont have 2 speeds . . just keep turning them around till you get it right.
Posted on Mar 11, 2008
SOURCE: oster 76
There can also be a problem with the switch, which can be gotten to by unscrewing the the 2 screws at the end of the clipper . . .you must then test (with the thing unplugged!!!!!!!!!) to see if the switch wires are good or if the switch is broken by flipping the switch and or the toggle and then checking the wires with an ohm meter (easily available from radio shack or ?? for under 10 bucks or any kid who's into electronics. If the switch is good, when its turned on resistance goes to 0, if bad th switch shoes infinite resistance on or off . . .
If it hums and the motor is turning, but the blades don't move you need to replace the gear and or lever . . see this diagram
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
  • 3 Answers
SOURCE: how to put oster golden a5 two speed head on
Go to: www.clipperrepair.com and look at the diagrams. It might help you. Also, I went to Oster's website and found help there with internal parts.
Posted on Oct 11, 2008
SOURCE: I need to replace the 2 speed oster A5 toggle
I have a picture of one, can you tell me where you got the new switch, I need to replace mine.
The center lead goes under the white wire.
The two end leads both go to one of the brass connectors
The black wire goes to the other brass connector.
Note the "Tab" at the top
Posted on Mar 11, 2009
philschneide
  • 448 Answers
SOURCE: I don't know how or where to apply grease to my oster classic 76
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear and teeth of bakelite gear). Also, the bakelite gear shaft has a hole down its middle and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Posted on Oct 11, 2009
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
The wires broke on the switch, I have resoldered them but am not sure now where they go?? Any help would be appreciated.
before you rewire your clipper I will put a video together for you, if you rewire your clipper wrong the clipper will short out and burn the clipper. please send email to ask@mannyssharpening.com for video.
Apr 23, 2011 | Oster Golden A5 2-Speed Universal Motor...
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
How to connect one speed toggle switch on oster classic 76 clipper.Thanks
e-mail askmannyssharpening@yahoo.com he will show you how with photo instruction. he ask for a donation for the cancer for women month
Apr 04, 2010 | Oster 76076-010 Hair Trimmer
I had to replace the back of my 76, cord, switch and all.. well i got the piece and when i install it my machine dont wanna power up, any suggestions ?
if your 76 clipper is a older model with a gray switch you install to black wire wrong. Now if this 76 is a newer model you have the tang position wrong. your best bet Contact mannyssharpening@yahoo.com they can help you with step by step instruction.
Feb 18, 2010 | Oster 76076-040 Hair Trimmer
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Lubricating motor
Here is schematic for repair and service. This is the A5, it is the animal version of the Classic 76.
and if u need parts see the link below for schematic and parts list for the 76.
http://www.clipperrepair.com/parts.htm?mid=106
Feb 01, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
42 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
