Question about Panasonic Heating & Cooling
Panasonic air conditioner CS-MVG103KE CODICI ERRORE H 19
tatunka
  • 85 Answers
SOURCE: Hi, my Panasonic CS-E12HKR air
http://www.aircon.ru/pbc_download/files/f1147680661.pdf its about the memory norefregerant. look at page 47 for error codes
Posted on Nov 14, 2008
SOURCE: Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Posted on Dec 08, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Getting the batteries out of the remote unit for a
Try sliding the remote cover all the way off
Posted on Nov 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
Panasonic air conditioner CS-E28GKR error code h15
(?15) - violation of the operation mode of the temperature detector of the compressor unit Panasonic
Oct 06, 2012 | Panasonic CS-A12C Air Conditioner
HO UN CONDIZIONATORE HAIER HSU-12RU03/R2,NON FUNZIONA E MI COMPARE SUL DISPLAY LA SCRITTA F22,QUAL E' IL PROBLEMA?CONFIDO IN UNA SUA RISPOSTA RISOLUTIVA.
Purtroppo, Haier non include dei codici di errore nei loro manuali proprietari. L'unico modo per scoprire che cosa significa il codice e la solutuion ad esso ? chiamare Haier clienti Sevice 1-877-337-3639
Aug 25, 2011 | Haier hwr10xc6 Air Conditioner
Panasonic air conditioner cs e28gkr, has error code f97.
f-97 out door compressor over heating due to in sufficient refrigerant. Check leak and arres ***. do gas charging.
Jan 01, 2011 | Panasonic Heating & Cooling
FAULT CODE H19? WHST IS IT? panasonic air conditioner cs/cu-e18jkr.
H-19 Error code means indoor fan mechanism locked. replace fan.
Dec 12, 2010 | Heating & Cooling
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR CONDITIONER - MODEL CS-E28HKR ?
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Nov 21, 2009 | Toyotomi TID-1800HP Air Conditioner
How to determine horse power of air conditioner
air conditioning units are measured in btu's stands for
(British thermal units)
6,000 BTUh to 10,000 BTUh will cool 400 sq.ft approximately
10,000 BTUh to 16,000 BTUh. will cool about 800 sq.ft approximately
16,000 to 28,000 BTUh will cool 2,000 sq.ft approximately
the idea is more but's the more cooling power it will have.
Aug 20, 2009 | Panasonic CW-XC203EU Air Conditioner
Heating & Cooling Logo
354 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
