I have a kemore elite smart wash he3t and keep getting the f 35 code after wash starts. Then the door will stay locked and it will shut off.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Elite HE3t washer, in the middle of a load, it stopped. it flashes dL, F
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
Sep 03, 2011 | Kenmore Elite 45986 Front Load Washer
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
Kenmore elite he3t washer door will not open, always showing as f22 error code
it is your safety latch on your door. On the front load washer it will lock the door and if there is a problem with the latch it will keep it closed to prevent injury. If you have cloths in there try unplugging for about fifteen minutes or so and then plug it back in.
May 07, 2011 | Washing Machines
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smart Wash Q Pack/Door will not lock/to start
The Tab that locks the door or click you would say is either broken or the door is out of alignment... might have to remove the tab and purchase and install a new one
Sep 18, 2009 | Washing Machines
Kenmore HE3t keeps flashing wash time.Won't start or cancel/pause
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 10, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
