Question about Kyocera CS-2550 Black and White Copier
Put a new drum unit in & copies are still very light.
  • 113 Answers
Check drum unit contacts if ok. remove the cylinder and cleaning blade and replace on the old unit
Posted on Sep 16, 2010
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: drum light on
ok..unplug the printer from the computer...and try it that way...you may need to re install the driver on the computer, and flash the memory from front panel on the printer..let me know after you recycle the printer.
Posted on May 31, 2008
Sharp 1641cs - Dark/black page after replacing drum & toner
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Jan 11, 2013 | Sharp AL-1641CS All-In-One Laser Printer
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
Light print on side of paper. color black copies, print, internal
Ninty-five percent of all image issues like this are caused by the carona-drum-toner assembly. I have not worked on this model but the only way to diagnose the issue is to try a new drum / toner cartridge and see what impact it has. Then once you resolve the issue you can discuss the service life after the fact.
May 12, 2010 | Brother MFC-9440CN Laser Printer
My printer drum light is lit and will not copy. I have put in a new drum and the is still lit and will not copy
Hi
Please follow the bellow instruction…
Open the front panel.
Remove the toner and the drum.
Remove the toner from the drum.
On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them.
Put everything as it was.
Turn on your printer.
Now, the low toner light should be gone and the green light should be on.
Now, you can empty your cartridge.
If the Drum light is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side.
Pres the control panel button until all lights are lit, and then release it.
The Drum counter is now reset.
Thanks for contacting fixya.com
Feb 02, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
CANON 1600
Try to clean the drum & shake toner & it's nothing to do with transfer roller for sure , it's your drum unit only . Another thing ,was your drum unit exposed to light for more time than normal , in that case try another drum ,try this i think that will solve your problem
Jul 10, 2009 | Canon imageRUNNER 1630 Copier
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Replacing drum unit on copier: Sharp SF 2114
Well, if the light under the glass doesn't come on, that means that black copies can hapen. Nothing to do with the drum or drum unit. Either the lamp burnt or the protecting fuse is blown. If you take out the glass, you can mouve the carriage with the mirrors to the right and you can see the exposure lamp. If it has dark ( like silver) bands on it, the lamp is burnt and its brightness will not be enough to make a copy. CHANGE THE LAMP. If the lamp is ok check the thermic fuse wich is in touch with the lamp carriage, and normaly it burns when taking a lot of copies in one go. The drum is a red cilinder that is in drum unit next to the developer unit where you put the toner. If you open the ma chine you can see it about the midle just above the transfer corona. If you don't get it right i can explain how to change the drum. GOOD LUCK.
Nov 02, 2008 | Office Equipment & Supplies
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
Kyocera CS-2550 Black and White Copier Logo
41 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
