Question about Apple Computers & Internet
Getting error c:\windows\system32\odbcint.dll cannot be loaded while trying to run itunes on windows 7 64bit
  • pramod_sachd Sep 15, 2010
    already tried that..
    Scholar:
  • 91 Answers
The dll file might be corrupted or missing, just reload the file.
Posted on Sep 15, 2010
Fix my vb script engine on my computer / Windows 7
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
I have a dell desktop 8300 dimension running on xp. when opening itunes an unable to locate component window pops up stating "This application has failed to start because JavaScriptCore.dll was not found....
This is due to the dll file is not registered. Try to register the dll file will resolve your problem. For this
1st step: search for JavaScriptCore.dll file and copied the same to system32 folder using search menu.
2nd Step: type regsvr32 JavaScriptCore.dll in run menu and enter, it will rigester the dll.
Still you are facing the problem, once again reinstall the application.
Revert back for more assistance and also give your valuable feedback/rating for the solution provided.
Feb 10, 2010 | Computers & Internet
I hit F8, here is the new error message
If this is all you are seeing, then this is not an error. What is happening here is that your computer is loading Safe Mode. This is a way to load Windows operating system without any extra software or programs, using the most basic drivers and software to load. There are a lot of benefits to accessing this mode, especially if you installed a program that stops you from getting into Normal Mode, or you have a virus that does the same. It makes it easy to troubleshoot. Here is a link to a website with a little more info:
http://www.computerhope.com/jargon/s/safemode.htm
If you load your computer normally by not pressing any keys, then you should be fine.
Mar 27, 2009 | HP Pavilion xt938 PC Desktop
Cannot get easycap usb to be recognised
the mmci.dll file may be corrupted. go to the following link and down load the dll file.
http://www.dlldll.com/mmci.dll_download.html
it should work with correct dll file
Feb 23, 2009 | Ulead Videostudio 8 for PC
The port the modem is attached to could not be opened; Opening the modem device failed with error 000005aa
Sounds like a hardware problem
First > try changing the modem port (default is com3, try changing it to com4 or com5 whichever is free)
Try querying the modem again
Second > Contact your modem manufacturer
May 26, 2008 | Conexant chipset 56K V.92 PCI Data/Fax...
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
My laptop wont let me use most programmes because of system 32
What specific error are you getting and what operating system do you have.
Jul 17, 2007 | LG X-Note LM50 Notebook
Computers & Internet Logo
461 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
