Question about Maytag Washing Machines
While in the spin cycle the machine jumps. I have tried rebalancing the clothes but it continues. Also, my neighbor told me the back was self leveling so he lifted the back and dropped it down. It didn't seem to help.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 16, 2008
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Mar 19, 2010 | Washing Machines
Jumps around
Mine did this, it never got fixed, repairman told me to replace it. I suggest you do the same. He told me the springs and bumpers had just worn out, and from the looks of my old washer, he was right lol
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't go through spin cycle
this happened to me. there are other things it could be but i was told the most common is a broken or unhooked suspension spring. I'm a housewife and i fixed it myself in about 30 min.
Jan 29, 2009 | Whirlpool GSC9455 Top Load Washer
Ge adora top load tub leans to one side, but works
There are 4 suspension rods that hang the outre tup from the top frame. One is the came off during the off balance load. Easy to put back on...Remove the front panel by inserting a putty knife where the top of the machine and the front panel meet inline with the lid opening while pulling towards you. You will then be able to see the front rods. The back two are harder to see but hopefully it is only one of the front rods that needs to be reset. When you see it and compare to one of the ones that didn't come loose, it will be obvious how it is attaches.
Dec 19, 2008 | Washing Machines
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
