Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
Oil change instructions and oil recommendation (lost manual)
  • 110 Answers
Hello, oil to use in the engine depends on engine if it is a Kohler you will want to use 10w30 approx 2qts. The Briggs & Stratton engines use HD30 or SAE30 approx 1.5qts. Use the dip stick to ensure you have the right amount and don't over fill.
To change the oil:
  • run engine about 10 minutes to warm up oil so it flows better
  • at the bottom of the dip stick there is either a valve or plug
  • open the valve or plug and let the oil drain (I use an old gallon oil container with a funnel) leave the dip stick out
  • while the oil drains; change the spin on oil filter
  • once all the old oil has drained replace the plug or close the valve
  • wipe down the funnel and use it to refill the new oil
  • use the dip stick to ensure proper fill level
I also recommend that you replace the air filter at the same time, if the engine can't get air is can't run efficiently.
If this is helpful please vote yes, Thank You!!
Posted on May 05, 2011
How do i oil my 3********** machine
Follow the instructions in your owner's manual. If it is a computerized machine, it should be oiled only as instructed.
Be sure to use fresh good quality sewing machine oil recommended in the manual.
If it is a mechanical machine, the instructions in the manual are the minimum oiling. Older mechanical machines will sometimes need a couple drops of oil every place that metal rubs against metal. Do NOT oil belts, synthetic parts, cams. AND do NOT over oil unless you want to be wiping up excess oil! A drop of oil on the hook/shuttle every 8 hours of use. Thorough oiling as described above, every 40 hours of use. If in storage or not in frequent use, every six months.
Oct 21, 2016 | Sewing Machines
Where do i put oil on a empisal mercury 404 overlocking machine
You should follow the instructions in the user manual. Use oil recommended by the manufacturer. Other oils can damage your machine.
Manual EMPISAL MERCURY 404 OVERLOCKER Operating Instructions Service
Apr 09, 2016 | Sewing Machines
Does a 2011 caddyTDi250 1.6 ltr need the gearbox oil changed when the vehicle has its regular service?its 5 speed manual gearbox,and is there a filter to be changed?
No but check with the dealer or your service/owner manual for the manufacturer recommended gearbox oil change periods.
There is no filter on the manual gearbox .
Whatever the manufacturer recommended period is for a gearbox oil change, change the gearbox oil twice as frequently as recommended to maintain it in good condition. If, for example, a change every 50000 miles is stipulated then do it every 25000 or so.
Nov 02, 2015 | Cars & Trucks
How to change oil pump
Changing the oil pump is not easy, the oil pump is situated in the engine oil sump. So you have to go under the car and remove the oil sump pan to get at it. First you have to drain the oil. I recommend you buy a repair manual such as Haynes from a auto parts shop for about $15 before you start the job and follow the instructions in the manual. Good luck
Jun 25, 2014 | 1999 Dodge Durango
2 synthetic oil change or 3 regular oil change so which is better
Me i find synthetic oil to be better in winter the engine turn faster in cold start but it mush more expensive to use synthetic if your looking to save money synthetic oil good for 15000 km regular around 5000km use synthetic oil because its better for the engine not to save money
Jun 10, 2014 | 2007 Acura RDX
The "low oil pressure -
It could be. The best is just follow your instruction manual on what type the oil should used on your car. But since your car is has the year 2006, it should use specs. API... SL or SM. The viscosity will has range 5W30 -10W40. Again don't get be cheated by the newest oil products, The best oil for your car is the one recommended on your manual in many aspects.
Regards, Jay
Feb 06, 2011 | Chevrolet Impala Cars & Trucks
Should I have the oil in transmission changed?
I would not go by the oil change company recommendation.
It's much better to go by the car manufacturer's recommendation. Look in your owner's manual for the recommended time/mileage to change the transmission oil and filter.
Jun 12, 2010 | 2004 Jaguar XJ-Series
What kind of oil do i use in my 06 dodge dakota, 6 cylinder manual truck?
most dodges take 5 quarts of 5w30. but to be sure it will say in your owners manual which grade and how much to use.
here is a nice instructional video to assist you iin changing your oil on a dodge dakota if you are inexperienced in doing so.
http://revver.com/video/183724/dodge-dakota-oil-change-repair-vide/
Jul 11, 2009 | 2006 Dodge Dakota
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
4,735 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
