Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
When the fan is on it makes a noise as if it is rubbing somewhere. The light is fine and the motor seems fine. Just some kind of friction that we are afraid to use it.
  • 377 Answers
Could be a simple alignment issue or the flywheel holding the fan blades to the fan could be going bad, i.e. dried out and crumbling.
The only way to check for sure is to get up to the blades and look to see the condition of the flywheel, a hard black rubber part and perhaps check the alignment of the fan itself.
Posted on Oct 06, 2010
  • pwillitz Oct 06, 2010
    I am sorry my solution was of no help to you.
I have a 4 year old RM5200 hood over my stove. The motor is making a whining noise. It seems to soon for this to happen. It is loud and constant to the point where we don't want to use it. Is it time...
Range hood motors, bathroom exhaust fan motors all share the same thing. They become coated with grime inside the shaft of the rmotor due to their exhaust feature of sucking dust and grime over the motor, which is open. The only solution is to get access to the motor and clean the fan blades and squirt a little WD-40 down the shaft as that is where the noise comes from. The dirt and grime build up on the motor shaft, and eventually starts rubbing the bushing where the shaft rest and makes a noise. Yo must remove this from the shaft and allow a little play, and lubrication which the WD-40 will supply.
Feb 15, 2011 | Rangemaster Kitchen Hood
Health Trainer 2.0 treadmill stopped. Readout says E-11. What does that mean?
The walking belt is moving slower that the console is showing. Many times, the same symptoms can cause an E11 and an E22 error.
  1. The most common problem is belt/deck friction. If you have a belt that has too much friction, it can cause a wide enough speed variation to create an error. You can try our World Famous lube to help but eventually at least the belt will have to be replaced.
  2. Before doing anything, check the drive system for a foreign object. A little "helper" can put a small ball in the drive system and you'll get an error code.
  3. Be aware of any noises the treadmill was making. If the treadmill had a screeching noise, the bearings in one of the bearings or motor could have had a problem. Read our help section on how to find bearing noise to isolate which part is causing the trouble.
  4. Make sure the motor fan is firmly attached to the motor shaft. There are a series of "fins" on the fan that are read by the speed sensor. If it is not properly attached, you can get a bad reading. Also if some of the fins have broken off, a bad reading results.
Check the wire from the speed sensor and make sure it is firmly in place on the sensor and the electronics. Make sure the S F/B LED on the controller flashes as the fan turns. This is telling you the sensor is reading properly. Clean the sensor with a Q-tip and rubbing alcohol if it doesn't flash and if that doesn't fix it, replace the sensor.
Dec 14, 2010 | Keys Fitness Exercise & Fitness
I have a Nice Samsung HD wide screen television that started making noise last week and this noise got proggressively louder and louder to the point that we cannot watch it now. It sounds like an internal...
Give me model number (it is on back and also should be on right side of cabinet)
I suspect it is a DLP set with a bad color wheel.
Wheel faces lamps in DLP type sets and bearings in motor fail causing either high pitched whine/fan like sound.
If wheel shatters set will shut down.
There are instructions and videos on You Tube for replacement of the kind of part---do it your self repair.
Look at photo and add comment here with model number.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Samsung Televison & Video
I have new Samsung 1.5 Ton Window AC ( around one month old). Whenever AC is switched on in FAN or Cool mode the AC (probably FAn motor) make irritating Humming Noise. The noise slightly reduces after...
It is possible that your AC is not getting the right voltage or frequency and hence is trying to scavenge in gettting the current. It will be good if you can check on the mains voltage or on the wiring for a good 15 amp supply line. If there is any reduction or load onthe wire then the voltage can drop considerably. So in the first place kindly check this out. If this seems in order you will have to check for the fan or the compressor motor to be humming. If your cooling seems fine then you can check on the capacitor of the fan or the starter motor. I am sure since this is in warranty you must make a claim to get a free replacement. Hope you find my advice useful Good day
Aug 03, 2010 | Maytag M6Q10F2A Air Conditioner
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Noise from the fan/fan motor
The bushings in the motor are worn out, replace motor. This should correct the problem.
Sep 10, 2009 | Refrigerators
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
Grinding noise every now and then
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Jan 22, 2008 | Cadco OV-400 Electric Single Oven
Noisey fan
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Dec 08, 2007 | Broan-NuTone N-8664RP Combination Light...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
111 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
