If we are going to summarize the problem:
1) The tdwconsulting.net email is not being recognized by your BlackBerry.
2) You are using the tdwconsulting.net to sync up with Google Calendar.
3) You need the tdwconsulting.net email to work with your BlackBerry, so that you could view the Google Calendar that is associated with tdwconsulting.net.
Let me explain this to you:
First, calendar sync is different from e-mail sync. Because they are running on different applications. Calendar sync is using the sync plugin and e-mail sync is using the BlackBerry Internet Service (BIS).
Second, I think that Google Calendar is still synchronizing with your tdwconsulting.net e-mail. It's just that this e-mail account is not getting sync with your BlackBerry, that is why the Google Calendar is not showing as well in your BlackBerry. It appears that the only problem is e-mail sync. Once you resolve this e-mail sync problem, the Google Calendar will also show in your handheld.
Third, all you have to do is to contact your e-mail provider for the domain "tdwconsulting.net" and ask for the INCOMING and OUTGOING Mail Servers for IMAP.
Once you have the correct, incoming and outgoing mail servers, check the e-mail account settings in your BlackBerry to verify if you have entered the correct mail servers. If not, then change the mail servers with the correct one.
Once you see that the e-mails for tdwconsulting.net starts to download in your BlackBerry, just wait until the handheld completed the download. And the Google Calendar should appear in your hand held again (if it was working before).
I hope this helps...and good luck!
Regards,
Firesnake09
Helpdesk Analyst / Messaging Specialist
