Question about Sony DVP-F25 DVD Player
Error C:31:00 keep ejecting CD/DVD and said not inserted correctly takes several attempts for the cd/DVD to stay in then the erroe is disc not inserted correctly C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
Posted on Oct 30, 2009
No disc error dvd
You need to try cleaning the lens of the player. If that doesn't correct it you might have lens damage.
Jul 28, 2013 | Harmon Kardon Harman Kardon Bds 400 2.1...
Toshiba dvr19dtkb keeps showing "disc error"
You need to have the cd/dvd drive replaced.
Sep 02, 2012 | Toshiba Computers & Internet
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
MY CD-DVD DOOR WILL NOT OPEN
This is sometimes cuased by either a faulty drive motor or even the Magnet which keeps the disc in place.
You can force eject the disc by taking a paper clip and straightening it out, then you insert the clip into the tiny hole under the CD tray and pressing it in firmly until the tray releases.
Mar 05, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Mecha error
Otherwise known as a mechanical error. The CD will not eject/insert without assistance. I have found a workaround for this, but have yet to fix it. If you take another CD and hold it inside the CD slot just beneath the ejecting CD, it will help to guide the CD out of the track. I also have to use a similar method to push the disc into the track as well.
Aug 14, 2009 | Kenwood DDX-6019 Car DVD Player
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Toshiba laptop won't burn cd from itunes
I had the same promblem. What you should do is make a serperate file on you desktop and drag all of your music that you burn or download to that folder first. Drag it to Itunes after that. Now, you only have to drag the songs to Itunes if you want them on there for you iPod. Take the songs from the folder, and drag them to windows media players burn list. Insert a blank disc and you should be good. Keep in mind that you can only do this if you put downloaded or burned music to the created folder first. If you take it to Itunes first, you will have to re-download or re-burn your music again.
Hopefully this helped you guys.
Nov 06, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Jul 19, 2008 | Eclipse CD3422 CD Player
Sony DVP-F25 DVD Player Logo
1,150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
