I have celestion k12b 300 watts what can i run them at your rab
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have a s1500 samson amp I keep blowing speakers,
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Posted on Feb 07, 2011
I have 115 v at the bulb receptacle but the bulb doesn't light up...whats the problem its a rab ff150 hps fixture
Does the bulb work in a different fixture? Sometimes the base of the bulb does not make contact with the terminal inside the fixture. unplug the fixture and then see if you can bend the center "not" connector up a little.
Nov 08, 2014 | Rab Lighting RAB FF150 - 150 Watt - High...
Tip
Find more Ferienwohnungen Rab
Willkommen auf der MisFerienwohnungen Rab der Insel Rab. Ferienwohnung Mis befinden sich in Palit nahe dem Zentrum der Altstadt von Rab befindet. <a href="http://www.mis-rab.com/index_ger.html" target="_blank">www.mis-rab.com </a>
on Aug 27, 2013 | Exercise & Fitness
Tip
Ferienwohnungen Rab in croatia
Willkommen auf der MisFerienwohnungen Rab der Insel Rab. Ferienwohnung Mis befinden sich in Palit nahe dem Zentrum der Altstadt von Rab befindet. <a href="http://www.mis-rab.com/index_ger.html" target="_blank">www.mis-rab.com</a>
on Aug 27, 2013 | Audio Players & Recorders
Hemco 6503HBLC 300-Watt Touch Dimmer defective
So long as you only use incondescent lights as it says on the switch and on the packaging you won't blow up the switch. the 300 watt is the maximum amount of lights you can have in total on that switch too. five 60 watt light = 300 three 100 watt light bulbs = 300
Mar 20, 2013 | Electrical Supplies
How much watts does a JL audio 10w0-8 have?
the 10w0-8 are 8 ohm speakers and rated rms is 125 watts, an amp running 300 watts is perfect and you need to wire it in series to pull a 4 ohm load from your amp. if amp is larger than 300 watts rms it will kill the w0's in a quick minute.
Mar 15, 2012 | Car Audio & Video
Hi i have a pair of celestion k15t-200's i need to know the impedence on these bad boys also are they 200 watts max or r.m.s ? thanks
Hi, With Celestions, it will be the RMS rating. I have one of these and it has "8 Ohms" stamped on the edge of the dark grey edge of the magnet, in black ink, so barely visible. Check around the magnet for any signs of print, it may be faint. They wouldn't necessarily all be 8 ohms. An 8 ohm speaker should measure about 6ohms on a multimeter (as the rating is AC impedence and the meter measures DC resistance). A 4 ohm should measure about 3 on the meter.
May 20, 2010 | Audio Players & Recorders
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Celestion Neodog Speaker
the mesa is for guitar and is not more than 100 watts, the neo dog is 100 watts it will fit but will give a different character because can be push to another limit of saturation the vox doesnt give that much.
Sep 10, 2009 | Audio Players & Recorders
Windows not running
Hi rab, windows in general will not allow you to go back wards to ME. Some laptops & other systems place a hidden partition at the top of the drive. These hidden partitions normally are around 2-4Mb in size. (Not enough for windows to finish install). So go to the link provided & create a bootable CD/DVD.
Darik's Boot And Nuke will completely erase the drive, (Including any hidden partitions). You can than install ME without an any issues. Download Darik's Boot and Nuke 1.0.7
http://www.dban.org/download
FAQ's: http://www.dban.org/faq/index.html
Good luck rab!
Mike
Vote.....
Jan 02, 2009 | Toshiba Portege 7020CT (P000272180)...
133 people viewed this question
 Grubhead
Grubhead
