Question about AEG Dishwashers
I have an 18 month old AEG Favorit 84980 V1 which fuses mid cycle. Any clues? Thanks , Paul
SOURCE: AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Posted on Jan 17, 2009
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
reddyanantha
  • 205 Answers
SOURCE: My mums AEG favorit sensorlogic dishwasher has
please check the timer
Posted on Nov 06, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Got an AL4 error on my AEG 64800
al4 is tripping of anti flood float switch in base of machine. look for a leak mopping out the base resets the switch
Jun 19, 2010 | AEG 18 in. Favorit 64800 Free-standing...
AEG Dishwasher 54850 not heating up the water is no getting hot
This could be the electrical element (some use the old traditional element and some (later models) use inductive heater coupled in line with the hose feeding the top sprayer arm. A test with an Ohm meter should indicate if the element is open circuit.
Aug 02, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Dishwasher runs full cycles but the water is cold each time.
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Jan 09, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
The dispenser flap doesn't open
you should check first that power is going to the dispensor at the appropiate part of the cycle. to get at the dispensor, split the door - its screwed together by screws round the periphery. dispensor is just held in by usually 6 obvious screws
Feb 27, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Dishwashers Logo
32 people viewed this question
Top AEG Dishwashers Experts
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
