Question about JVC Televison & Video
Dark shadows, black areas when TV turned on, fades after awhile
  • claudia_dora Sep 16, 2010
    Where do I find the inverter board? It is a JVC LCD
    Very helpful, thank you.
  • JVC Master
  • 11,800 Answers
The causes for that depend on what type of tv you have:
- if it's an plasma or a CRT (direct or projection) then this is a sign of aging screen, it;s time to start saving for a new one.
- if it's an LCD then the backlighting tubes are malfunctioning because their inverter board (the one that powers them ) is starting to fail - you will need to test and (if fixing is difficult) replace it.
- if it's a DLP or LCD projection then the optical engine is starting to fail this is terminal since a new one costs almost $1000. Time for a new one.
Posted on Sep 15, 2010
  • Azrael SRL Sep 16, 2010
    You have 3 options:
    1 - order a replacement directly to the JVC dealer - this will be expensive, it will probably require that you bring the tv to their repair shop, but it's fast and easy.
    2 - get an replacement board from a site specialized in tv parts' one like
    http://www.lcdtvparts.co.uk/index.php?ma...
    You will need to do a lot of searching to find the exact part for your tv
    3 - get your board refurbished professionally by a company like
    http://www.moduslinkptstvboards.com/
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Was printing photos all was ok then printer stoped printing black
There are 4 inks, cyan, magenta, yellow, and black. When the black runs out, you are left with sort of a dark purple or brown color.
Oct 03, 2009 | Canon I900D InkJet Photo Printer
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Dark vertical shadows
No,you can't. This is very common. I bought a new tv and i noticed right away that it had the problem you are mentioning. I took it back for an exchange and the next tv did not have this problem...until a year later. Now,of course it does have this problem,but it is out of warranty.
I think they make televisions very poorly today.
Apr 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Print quality
Change the PCU cartridge.
Mar 01, 2008 | HP LaserJet 1020 Printer
Durabrand TV picture died. 2 yrs old
hats the shelf life on that tv
Jan 21, 2008 | Durabrand DWT1905 TV
When the tv has been on awhile
Do the smudges move around or are they in the same position all the time??If they appear in the same position it sounds like you are having a problem with the invertor panel or the back light circuitry.If you could post photo of fault would be helpfull
May 11, 2007 | Panasonic TX-26LXD1 26 in. LCD Television
Televison & Video Logo
296 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
