Question about Faber Perla 602599 Kitchen Hood
Model: Strip PB X A 90 extractor hood How do you change the light bulbs?
Hi I have an Ikea cooker hood/ extractor fan, fan is working but lights ( 12 V. GU4 ) are not. Just replaced the bulbs but no joy.....
Without the MODEL Number... and the 12v GU4 lamp... I am going to HAZARD A GUESS that your lighting has an internal TRANSFORMER... (most likely)...
But there are less expensive things to check first
Since this is now a GLOBAL SITE you will have to disclose your Line power... (USA: average household range hood = 120V 60 cycle AC current)...
ERGO:
transformer is a 120v to 12volt output (live measurement)
For walk up TROUBLE SHOOTING
"Multi-meters" are a must...
Opening assumption
THAT YOUR NEW BULBS are good... is understandable... but possibly wrong (I'm just saying).
Power OFF
- Verify bulb continuity
- Verify switch operability
Happy hunting
Carnac the Magnificent
Feb 07, 2017 | Kitchen Ranges
Lights have stopped working on my whirlpool extractor hood at the same time. Bulbs are ok and fan works. Model AKR 906. Please help.
first check the lamps in another device since it some times shows its ok bur actually it is not.then look for false connections and at last the holders if the lamps went out one by one.if all together then it must be the switch.
Nov 28, 2012 | Kitchen Ranges
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Hi my Kuppersbusch fan is not working. Is this common, any suggestion?
My extractor hoods lights have stopped working(2X 20W). I've replaced the bulbs with new ones but no joy!
Any suggestions?
Carl Dally
Oct 23, 2009 | Kuppersbusch K IKD12250.0E Island Range...
Light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
Jun 22, 2009 | Kitchen Ranges
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Faber Perla 602599 Kitchen Hood Logo
271 people viewed this question
Top Faber Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
