Question about Panasonic KX-T7633 Corded Phone
Do not know my code to get my messages - is there a way to override it ?
  • Panasonic Master
  • 2,460 Answers
The system owner with the access code to mailbox 999 can reset your password. If you lose that one, the dealer can log into the voice mail system and reset MB 999's password.
Carl
Posted on Sep 16, 2010
Canon Mg3150 fault code E6, how can I fix it?
Do you mean fault code E16? That means the ink has run out. You can bypass this error message by following this YouTube video:
Canon MP230 Override Empty Cartridge Message
Feb 26, 2015 | Canon PIXMA Office Equipment & Supplies
AVAYA PARTNER MLS12 MESSAGE LIGHT ON
Try disconnecting from battery, if it is the security code wont be removed
May 21, 2008 | AT&T Lucent MLS-12D Phone
I would like to know how to unlock a awa 50 inch plasma tv without using the remote as i have misplaced it
Hello
If your Apex has a Menu button on its front panel you can unlock it by the following method. If not, you must have its remote control handset. To unlock it:
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Ok
Apr 27, 2011 | Apex Digital AT2002S 20" TV
How do i unlock a Gt 3215 apex tv? and where and how does the function button look like on a remote??
Hello
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Function buttona nd Menu buttons are the same or some remotes. I don't know whether you have the original remote of Apex or not. On original remote there is a function buttom marked as Function.
OK>
Jan 06, 2011 | Apex Digital GT3215 32" TV
How to unlock the Apex AT1302 parental control without knowing the code?
Hello
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions as well as set a new code.
OK.
Dec 03, 2010 | Apex Digital Televison & Video
How do I remove the parental code if I dont know the pasword.
Hello
Nov 18, 2010 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Have a code alarm for car remote dont work and cant disable it. wont start how do i disconect alarm so car will start
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Aug 03, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
How do I override a message empty color cartridge,
You cannot override the message, yellow may have ink in it, but it's probably dried up inside.
Oct 16, 2009 | Brother Office Equipment & Supplies
Child lock on and do not know how to disengage
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Apr 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Panasonic KX-T7633 Corded Phone Logo
71 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
