Question about Keurig B50 Coffee Maker
My keurig coffee maker will not draw water into the tank and shuts off after a minute.i hear the pump but it wont draw water
  • Anonymous Mar 29, 2014
    hEAR SOUND BUT WATER DOESN'T COME THROUGH TANK
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
  • 1 more comment
  • jimmyjazz123 Apr 18, 2011
    My Keurig SS700 quit pumping water completely. I tried the de-scaling. Didn't work. I cleaned the needle with a paper clip. Instant fix. Now descaling. Thanks much Diceman51.
  • Diceman51 Apr 18, 2011
    Glad it helped.
  • molly johnston
    molly johnston Jul 28, 2014
    i cleaned it out with a paper clip and it still makes the sound and says not ready on the screen. it doesnt take any water out of the tank and then it turns off.
You can hear the pump pulling the water from the resevoir but it just comes out the overflow back into the tank
pinched flow tube ? it boils through the tube then shuts off @ boiling no pump yet >
Dec 19, 2010 | Keurig B60 Coffee Maker
My B70 loses prime when drawing water from the reservoir. After a few seconds of the pump running and no water being pumped, the unit will automatically shut off. The reservoir is fully seated. Does...
The problem might be common however, Keurig does not have any repair centers around the country, nor do they have schematic drawing available :(. In order to get your problem taken care of you have to call Keurig directly 1.866.901.BREW
Sep 15, 2010 | Keurig Platinum B70 Coffee Maker
Have to lift and reset the water tank each time to have water pulled into system. Any fixes?
No mine is doing the same thing. Keurig said they redesigned water pump recently. It acts like it is vapor locking at times so it does not draw in water. I am returning this model.
Feb 07, 2010 | Keurig B60 Coffee Maker
My keurig coffee maker dos'nt stay on it will make one cup of coffee then shut itself off I have to keep turning on until you can hear the water heaing up and it also seems noisy I have only had this coffe...
There is a design flaw with the new Keurig units. They don't always draw water after brewing a cup. Some people say the company is using a weaker pump so they are less noisey. Some success if you remove water tank and drop it securly back in place. This seems to unstick the vavle.
Feb 02, 2010 | Keurig B60 Coffee Maker
My keurig coffee maker keeps shutting itself off. This is the second one weve had with this problem.
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. The constant reservoir adjusting may be necessary periodically and seems to be a design flaw with this model. Hope that helps! Best of luck...
Jan 31, 2010 | Keurig Special Edition B60 Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Keurig will work only part time. Sometime will make one cup of coffee and then will not draw in the water for the second cup and shut itself off after 1 or 2 minutes. Has plenty of water in it just won't...
Jan 16, 2010 | Keurig B60 Coffee Maker
Have Keurig B66 have moved and tried to start by filling the reservoir but i don't hear the pump take in the water and the indicator flashes NOT Ready. What do I do? I don't have the manual.
Dec 29, 2009 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
4,446 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
