Question about Panasonic Lumix DMC-FZ18K Digital Camera
Memory card is locked - Panasonic Lumix DMC-FZ18K Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 20, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 15, 2010
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My memory card is locked
Remove the memory card - take your finger nail and slide the tiny lever that says "lock" on the side of the memory card to the "unlock" position. Then reinsert the memory card and it will no longer be locked.
Jul 13, 2011 | SanDisk 1GB microSD Memory Card
To clear sd memory card password
i cant to delete files from my memory card
Mar 20, 2010 | SanDisk 2GB microSD Memory Card
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
227 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
