The image is upside down and I can't find any setting that could allow me to flip it
  • adela_p0p Sep 16, 2010
    Sorry, my mistake, I forgot to say that the image I'm talking about is actually the webcam. when i turn it on, the image is upside down. I understood it's something very common for Asus notebooks.
    So yea, this changes the whole situation. Sorry!
  • 480 Answers
You can normalise the screen by a keyboard short cut. Just press Ctrl+Alt+ (arrow key) to flip the window to normal settings.
Thank you for choosing Fixya.com
Posted on Sep 15, 2010
    Scholar:
  • 128 Answers
If your machine monitor shows an upside down display all you need to do is to press ctrl+alt + up or down button to fix the issue.
All the best!
Musicaddict
  • fixmenowplea Sep 25, 2010
    tried ctrl alt up or down
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
When I attempt to use my USB2.0 UVC VGA WebCam, the image that pops up is upside down.
There should be a setting in the camera software, that sets the mirroring or rotation of the image. Play around with the mirror-flipping options or the rotation factor to get the image right. If it's filpped upside down, a Flip Vertical should do, or a 180 degrees rotation.
If you find this post helpful and informative please vote with a Thumb Up. Thank you.
Jan 19, 2011 | ASUS K50IJ-C1 Notebook
The Infocus logo image is up-side-down even without connecting to the computer.
Many projectors allow you to vertically flip the image for mounting the projectors upside down. Each projector is different in how to change that setting, so I would look in your owners manual.
Mar 11, 2010 | InFocus IN36 Projector
Picture is upside down
Mar 09, 2010 | NEC MultiSync LT84 Multimedia Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Can I get an upright image with camera mounted upside down
Flip the image in post. Most editing programs have a vertical flip effect that will fix everything
Jan 29, 2009 | JVC GR-SXM260U Camcorder
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Rotating the image.
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Sep 20, 2007 | Hitachi PJTX100 Multimedia Projector
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
