Question about Iomega Computers & Internet
I believe the area where the cord is plugged into the external hard drive has been damaged. The light no longer comes on and I therefore cannot get the data up on my computer screen :( Is this at all fixable or did I manage to lose all of the data I have on my external hard drive?
    Problem Solver:
  • 5 Answers
If the socket is damaged you can purchase a new hard drive enclosure off the net for just a few pounds. All you need to do is up plug the leads from your faulty drive, open it up and locate it into the new enclosure. You will need to know what type of drive you have before you order the enclosure, it could be 2.5" or 3.5" - ide or sata.
Posted on Sep 15, 2010
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
Oct 06, 2013 | Verbatim SmartDisk Firelite Portable USB...
000 wd5000c035
If it's the power adapter then a simple search of the internet should show you where to go to find one. The other problem is that the HDD may be bad. You'd have to open the case, remove the HDD then connect it to your computer. I'm sure this would void the warrenty. However if it is the HDD then you saved yourselp the cost of a power supply.
Aug 27, 2013 | Western Digital Elements powered by WD 320...
My external drive no longer shows that power is going through and therefore not accessible . what could be the problem?
If it is powered over USB, try changing the USB plug to another port. If powered on DC, power supply is corrupt. If powered over USB and alternate port not fixing it, try replacing the USB cord.
Jan 11, 2011 | Buffalo Technology MiniStation Cobalt 320...
When plugged into the USB, SimpleTech Mini 250 will not come on
Did the light ever come on, or is this a new drive?
How old is the system? (It appears to require a power cord for USB 1.1, but not 2.0.)
If it worked in the past, as long as you have the same type of connectors (A, B, mini) on the cord ends, any USB cord should work. Just swap it out.
Apr 22, 2010 | SimpleTech Signature Mini 250GB External...
Acomdata external HD not read. Clicking sound.
Try taking it out of the casing and putting it into another external hard drive case. That is if you can, if its making a clicking noise it probably means your hard drive went bad or it means its not getting enough power to run make sure all the cords are hooked up tight. I had that problem once the hard drive wasn't getting enough power and i had to mess with it on the inside to make it have enough power. I'm not saying take the hard drive apart im saying take the casing off it and check the inside cords to see if they are tight enough. If that doesn't work leave a message and ill try to help again.
Jan 04, 2010 | Acomdata HybridDrive E5 Hard Drive
My maxtor external hard drive has stopped working. When I plug the power in the light only comes on temporarily therefore i can't use it. Have I lost all my saved data?
My maxtor external hard drive has stopped working.There is a chance that you can recover data using a USB to IDE or SATA Adapter Cable to recover your data they cost about $30 if you cant get hard drive to power with adapter chances are it has crashed there are places that can get data off hard drive but they are very pricey hope this helps.
Nov 28, 2009 | Maxtor Computers & Internet
Dvr no longer recognizes hard drive
Try switching around some wires.
If that doesn't work then it might be damaged.
I suggest plug it into another computer to see if it still works. Find out if it's the hard drive or the computer.
Jul 10, 2009 | Computers & Internet
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
Dropped the 'My Book Essential' 500MB, now doesn't work
ok wow i dont even think i dropped mine but it doesnt work.. like the light flashes when i plug it in but then it isnt recognised...
Feb 03, 2009 | Western Digital My Book Essential 500GB...
Computers & Internet Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
