Question about Rancilio Silvia Espresso Machine
Hi, the coffe part of the machine works, but the steamer doesn't. The steamer light comes on when I switch the steamer button to "on position", but there seems to be no water pressure at all when I turn the circular steamer knob. Any idea what this may be? thanks, Birgitte
  • Rancilio Master
  • 1,711 Answers
Posted on Sep 15, 2010
Coffee won't go because of the first light and I've lost the manual
there migt be few cause, one, checthe water flow sonde that have a magnet wich activat it, also the recipient for residual coffe and water is not in place, also the group wich prepare the cofee is not in the right position another possibility is the temperature of steamer is not 95 deg.. or the sonde is not proper
Nov 03, 2012 | Coffee Makers & Espresso Machines
No coffe is coming into the cup but the steamer works fine so water is getting through
HI
Your 3 way valve is bad. Its behind the panel that has 2 screws behind the the brew head. It slides to the right to remove. The 3 way valve has to be replaced.
Mar 31, 2011 | Rancilio Silvia Espresso Machine
The alarm light to empty the coffe grounds drawer AND the descaling light flash alternately I cleaned the brew group. Machine comes ready, but when I press to make a coffee it comes back with alternate...
Hi, the problem with your machine is with the grinder motor (not working).As soon as you press the coffee the CPU senses the motor is out of circuit and the lights start flashing alternately.
You can test it by doing this. Press and hold the steam button and switch on the machine, you will see the lights going around in anticlockwise direction. Release the button then turn the dial to left (Min) and press the steam button the grinder should work. The dial on the right (Max) the brew group will come up..and half way it will come back to normal position. Press the coffee button in that position will work the pump. Servicecenter can fix this if the machine is less than 2 year old FOC.
Oct 10, 2010 | Saeco Odea Go
COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Jun 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Saeco Gran Crema Espresso does not pump water
The machine needs to be primes.
Please trie and release hot water though the steam nossle.
Do like this
Open the steamer and then trie and make a cup of coffe. this will make the hot water come out thought the steamer instead of the coffe outlet.
Why you should do this is becuse the machine has it alot more easier to prime it self though the steamer then the coffe outlet.
Jun 21, 2008 | Saeco Gran Crema Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Cannot express the coffee into the cups
Solution nr one cold be the machine ran out of water and the circuit need to be filled up again.
This is the procedure to do that
Fill up your water tank
Open the steam knob na push the coffe button...in that way the water will be forced to go to the steamer.If you have water in the steamer like you asking for hot water....go to the next step
Close the steam knob and at that point you will hear a different noise and the watewr should be able to go direct into the boiler and start dripping like it was before.
if you don`t have hot water coming oput from the steamer....the problem is before the boiler and could be a clog on the silicon tube or the water pump is loosing friction..
Pls don`t forget to rate your experience
Fabio
Apr 26, 2008 | Saeco VIA Venezia
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email gethudall@hotmail.com
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
Rancilio Silvia Espresso Machine Logo
513 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
